Amount of singular points
In summary, a complex analytic function can have an uncountable set of singular points if the set of non-analytic points is closed and the function is analytic on an open, connected set and cannot be analytically continued outside of that set to a larger open, connected set. This is known as a domain of holomorphy and is a concept in several complex variables. Other equivalent conditions for having a domain of holomorphy include having a strictly pseudoconvex boundary in the complex plane or having vanishing analytic sheaf cohomology on a manifold.
jostpuur
2,116
Is it possible for a complex analytic function to have an uncountable set of singular points?
Analytic where? Obviously, a function that is analytic everywhere has NO singular points. Am I correct that by "singular point" you mean a point at which the function is not analytic? Certainly it would be possible to define a function that would be analytic everywhere except at certain points and I see no reason why one could not do that for and uncountable set of points. The only requirement would be that the set of points on which the function is not analytic would be a closed set.
it depends what kind of functions you want to allow. you want of course a function which is analytic on some open, presumably connected set in C, and which cannot be analytically continued outside that set to another strictly larger such open connected set, right?
well it is a theorem that every open connected set in C has such functions. A maximal domain for a complex holomorphic function, i.e. one for which there exists a function with no larger holomorphic extensions, is called a "domain of holomorphy", as i think i recall from my brief stint as a complex analyst in 1974-5.
this term is coined in the theory of several complex variables, since there it is no longer true that all open connected sets are such domains. but in one complex variable, all open connecetd sets are domains of holomorphy.
so i agree with halls that essentially the only requirement for the set of non holomorphic points is to be closed, in particular you could even have the open domain be dense in C. for references you can see gunning and rossi, or hormander.
there are other equivalent conditions in more variables as i recall, such as having a strictly pseudo convex boundary in C^n, or for a manifold having vanishing analytic sheaf cohomology ?, or ... hmmm memory fades after 30 years of disuse.
but
http://en.wikipedia.org/wiki/Domain_of_holomorphy
seems to confirm most of what i said.
I was thinking about some kind of divergence. Log(z) is not analytic on the negative real line, but that is not a kind of example I was thinking.
[tex]
\sum_{n=1}^{\infty} \frac{1}{(z-n)^2}
[/tex]
is an example of a function that has countably infinite set of singular points. But how could one get a concrete example of uncountable set on singular points? You cannot define it with sum like this at least.
Yes the analytic continuation is what I've been wondering, although I didn't make it clear yet.
For example a function
[tex]
f:\;]-\infty,1[\;\to\mathbb{R},\quad\quad f(x) = \frac{1}{1-x}
[/tex]
cannot be extended to values x>1 using analytic continuation on the real line. However it is possible through analytic continuation into to the complex plane, because there (1,0) is a point that can be gone around.
So I was thinking, that could similar obstacles come on the way of continuation also on the complex plane. For example a line [itex]l=\{x_0+iy\in\mathbb{C}\;|\;y\in\mathbb{R}\}[/itex], where x0 is a constant, so that [itex]f(z)\to\infty[/itex] when [itex]z\to l[/itex].
This seems to answer my original problem.
What is the definition of a singular point?
A singular point, also known as a singularity, is a point in a mathematical function or surface where the function or surface is not well-defined or differentiable. This means that at a singular point, the function or surface is either undefined or has a discontinuity in its derivative.
How is the amount of singular points determined?
The amount of singular points can be determined by taking the derivative of the function or surface and finding the points where the derivative is equal to zero or undefined. These points are known as critical points and may or may not be singular points.
What is the significance of singular points in mathematical analysis?
Singular points can provide important information about the behavior of a function or surface. They can indicate where the function is not smooth or where there may be a change in the behavior of the function. In some cases, singular points can also help identify critical points that may be local maxima or minima.
Can a function or surface have an infinite amount of singular points?
Yes, it is possible for a function or surface to have an infinite amount of singular points. An example of this is the function f(x) = 1/x, which has a singular point at x=0 and an infinite amount of singular points as x approaches 0.
How can singular points be classified?
Singular points can be classified as either removable or non-removable. Removable singular points can be "smoothed out" by redefining the function at that point, while non-removable singular points cannot be smoothed out and must be treated separately. Singular points can also be classified as isolated or non-isolated, depending on whether they occur in isolation or as part of a larger set of singular points.
  • Science and Math Textbooks
  • Quantum Physics
