Can an LDR be used in a proximity sensor for coursework in Advancing physics?
  • Thread starter Thread starter eRazed
    Ldr Sensor
The discussion centers around the feasibility of using a Light Dependent Resistor (LDR) in a proximity sensor for an AS level Advancing Physics coursework project. The original poster is considering a setup involving an LED and a potential divider to measure voltage changes as an object is moved at varying distances from the LDR.
  • Participants discuss the potential issues with using an LDR, including the influence of object characteristics on reflected light and background noise. There are suggestions to consider using an LED as a reference object and to conduct the experiment in a dark room to mitigate noise. The idea of using ultrasound as an alternative method is also introduced.
The conversation is ongoing, with participants exploring different methods and considerations for the proposed experiment. Some guidance has been offered regarding the limitations of the LDR approach and alternative techniques, but there is no explicit consensus on the best method yet.
Participants are navigating the constraints of the project, including the accuracy of measurements with varying object types and the challenges posed by environmental noise. The discussion reflects a mix of practical experimentation and theoretical considerations.
eRazed
I am just about to start my AS level Advancing physics - Sensors coursework.
I was wondering whether it would be a good idea to build a proximity sensor using an LDR in a potential divider.
I would reflect an LED off an object, and move the object at different distances away from the LDR.
I would take readings of the voltage across the potential divider output with the object at these different positions, and plot/analyse graphs of distance against voltage.
Would this be a good idea? Or would I get a series of inaccurate and unreliable results?
There are two issues here:
- the amount reflected back to the LDR will also depend on the particulars of the object (meaning you can't accurately determine distance for an arbitrary object)
- background noise... there are some simple ways to get around this that I can tell you if you want.
If you are serious about measuring distance I would suggest ultrasound. It is also possible to do this with light but short distances are very difficult due to the high speed of light.
could I get rid of the first issue by using an LED to replace the object?
Wouldn't doing the experiment in a dark room fix the noise problem?
If not, how would I do an ultrasound sensor? I'm not really very familiar with them.
To a certain extent an LED object will "fix" the first problem but you'll need to keep the orientation constant. And yes, a dark room will get rid of most of the noise. But this isn't really a realistic situation is it? Depends what your main goal is I suppose.
The idea with the ultrasound is to make a sonar... send pulses through the transducer and measure the time delay. It will be more complicated than your LDR system.
  • · Replies 45 ·
