Calculating Force exerted on a skydiver when Parachute opens?
  • Context: Undergrad
  • Thread starter Thread starter Hazarrd
    Force Parachute
The discussion revolves around calculating the force exerted on a skydiver when a parachute opens, focusing on the deceleration experienced, the skydiver's mass, and the impulse of the force. Participants explore different methods and concepts related to momentum, energy, and the effects of gravity.
  • One participant seeks to calculate the force in Newtons exerted on a skydiver upon parachute deployment, given the deceleration, velocity, and mass.
  • Another participant suggests using momentum and energy equations to relate the change in momentum and energy to find the force.
  • A different viewpoint proposes that if the deceleration and mass are known, the net force can be calculated by multiplying them and then subtracting gravity to find the parachute's force.
  • One participant questions whether to use the mass of the parachute or the skydiver when calculating the force, suggesting confusion about which mass is relevant.
  • Another participant clarifies that the skydiver's mass should be used since the deceleration pertains to the skydiver, not the parachute.
  • Impulse is discussed as the change in momentum, with participants exploring how to determine the change in velocity or the time over which the force acts.
  • One participant raises a concern about the complexity of the problem if the deceleration is attributed to the parachute alone, noting the influence of air resistance.
  • A later reply indicates that the participant has measured the deceleration using an accelerometer during a jump, providing a specific context for their inquiry.
Participants express differing views on the appropriate mass to use in calculations and the implications of deceleration measurements. There is no consensus on the best approach to calculate the force or impulse, and the discussion remains unresolved regarding the complexities introduced by air resistance.
Participants highlight the need for clarity on the definitions of deceleration and the forces at play, particularly regarding the roles of the parachute and air resistance. There are unresolved questions about the available data and how it impacts the calculations.
Hazarrd
Calculating Force exerted on a skydiver when Parachute opens??
Ok. So i want to calculate the force in Newtons that is exerted on a skydiver when the parachute is deployed. I have the deceleration that the parachute causes, the velocity that the skydiver is going right as the parachute is deploying and the mass of the skydiver. How would I go about finding this?
My followup question is: How would I find the impulse of this force? Is it just the force multiplied by the amount of time the skydiver experiences it for? Thanks! :smile:
I would use energies and momentum.
First, the change in the skydiver's momentum is:
[tex]Ft = \Delta P = m\Delta v = m(v_2 - v_1)[/tex]
Second, the change in the skydiver's energies is:
[tex]W_F = \Delta E_k + \Delta E_p[/tex]
[tex]F\Delta h = \frac{1}{2}m(v_2^2 - v_1^2) + mg\Delta h[/tex]
Now what you need to do is relate Δh to t (the time it takes the parachute to completely open) and solve the equations for F. I've assumed that the force exerted on the skydiver is constant throughout the parachute openning.
Well, after reading your question again it seems you don't have to go through all that. If you already have the deceleration caused by the parachute, and the skydiver's mass... just multiply them to get the net force on the skydiver, and substract gravity to find the force exerted by the parachute. :smile:
Hey, that's what I was thinking also. But I;m wondering if I should multiply the decleration by the mass of the parachute or the mass of the body? Since the parachute is the acting force would it be the parachute mass? Thanks!
Also, any idea how to find Impulse? :redface:
You should use the skydiver's mass, because you are working with the deceleration of the skydiver (it doesn't matter what object causes the force).
Impluse equals change in momentum, so:
J = ΔP
FΔt = mΔv
So you need to either find the change in velocity of the skydiver, or the amount of time the parachute exerts the force on the skydiver. I honestly can't see how you can find either of them, at least with the information that the problem provides. Are you not given any more data to work with? :redface:
Hazzard,
The answer depends on what you mean by "I have the deceleration that the parachute causes". Do you mean:
Do you really mean:
1) "I have the the deceleration that the parachute causes"
Or do you mean:
2) I have the the deceleration of the diver?
If it's #2, just use that deceleration and the mass of the diver in Newton's 2nd law and add the force of gravity (mg).
But if it's #1, it's not so easy, because the parachute isn't the only thing causing the diver to decelerate. There's air resistance to consider as well.
what is the deceleration of the diver?
I mounted an accelerometer on my helmet while jumping. I have the deceleration value that the head incurs because of the parachute opening. Thanks.
9K
  • · Replies 19 ·
