What is the acceleration of a jojo falling down a string?
  • Thread starter Thread starter olympiad
    Interesting
The discussion revolves around a physics problem involving a jojo (yoyo) falling down a string, modeled as a system of cylinders. The original poster describes the challenge of calculating the acceleration of the jojo as it rolls down the wire, while also addressing the rotational inertia of the system.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore the rotational inertia of the system and the application of the parallel axis theorem. There are discussions about analyzing the motion as pure rotation and the use of energy considerations to approach the problem. Some participants question the definitions and terms used, such as distinguishing between angular momentum and rotational inertia.
Several participants have provided insights and suggestions for approaching the problem, including the use of Newton's second law for rotation and the need to recalculate the rotational inertia. There is an ongoing exploration of the relationships between torque, force, and acceleration, with some participants expressing uncertainty about their calculations.
There is mention of potential confusion regarding the application of the parallel axis theorem and the need for clarity in the definitions of terms. The original poster indicates difficulty in simplifying the resulting formulas, which may reflect constraints in their understanding or the complexity of the problem.
olympiad
an interesting problem
I came along this problem, it is quite interesting. However, I have worked with the problem to long and than you can't see any new ways. So I thought, maybe you guys could try it with a fresh mind. Good luck, it is a tough one (or I fail to see something obvious)
imagine a jojo on a string which can be represented by three clinders, the middle one(with the wire around it) with mass m1 and diameter/2(I don't know what that is in english, in dutch it is straal)R1, and the two cilinders on the sides of it both have mass m2 and R2.
first give the rotational inertia on a horizontal axis through the center of mass point.
that was easy, 1/2m1*r1^2+m2*r2^2.
the second question was: calculate the accelaration when the jojo falls down( it rolls down the wire and the axis all stay in the same alignment).
here I got stuck. I thought, you can analyse the movement as a pure rotation around the point where the wire is connected to the middle cilinder. then the angular momentum becomes 1/2m1*r1^2+m2*r2^2+(m1+2m2)*r1^2 (paralel axes law.) speed is then expressable as (m1+2m2)hg=1/2(Ip)W^2. However, if you fill this in and try to express the speed, you get a gigantic formula that can't be right. I must be taking a wrong route, after all, I need the acceleration, not the speed, but I don't know how to come there.
Help would be greatly appreciated.(I am always a bit messy in my work, so it is possible that I made a mistake in the start of the answer)
sorry for my poor english, especially on physics therms.
faithfully,
olympiad..
You might be better off posting each question in its own thread. That said:
Question 1:
How about considering this as an energy problem? You should be able to figure out the torque and angular distance the that yoyo goes through.
YoYo problem
olympiad said:
first give the angular momentum on an axis through the gravity point(center of mass point)
I assume the question was: calculate the rotational inertia about the center of mass? If so, that's fine. (What you are calling "angular momentum" is actually the rotational inertia.)
here I got stuck. I thought, you can analyse the movement as a pure rotation around the point where the wire is connected to the middle cilinder. then the angular momentum becomes 1/2m1*r1^2+m2*r2^2+m1*r1^2 (paralel axes law.) speed is then expressable as (m1+2m2)hg=1/2(Ip)W^2.
Again, what you are calling "angular momentum" seems to be the rotational inertia. I believe that you made an error in applying the parallel axis theorem. Redo that calculation as you will need it.
In any case, there is nothing wrong with treating the motion as instantaneously a pure rotation. I wouldn't bother calculating the speed. Instead, calculate the acceleration directly using Newton's 2nd law for rotation. You know the torque about that point and the rotational inertia (recalculate it).
PS: I agree with NateG. Take your second problem and create a new thread. (Then delete that post in this thread.)
Of course, that's much more logical. I wanted to take the differential formula of the speed, but that's the hard way I guess.
so the T=FR. F is g(m1+2m2), R is R1. T is R1*g(m1+2m2). T=Ia. the mistake I made in using the parallel axes theorem was that I didn't use all the mass, isn't it? the therm added should be (m1+2m2)R1^2, so I is 1/2m1*R1^2+m2*R2^2+(m1+2m2)R1^2. a= T/I so a is (R1*g(m1+2m2))/(1/2m1*R1^2+m2*R2^2+(m1+2m2)R1^2). Then, At(acceleration of the center point) is a*R1. so At(what I need)=(R1^2*g(m1+2m2))/(m2*R2^2+(1.5m1+2m2)R1^2).
Somehow that doesn't seem right.
The problem is that it isn't possible to simplify the formula since i can't turn the divider into one therm.
Is this right then?
thanks
olympiad said:
Is this right then?
Looks right to me.
ok. Thanks for the help
  • · Replies 20 ·
