Maximizing Scalar Increase: Understanding the Direction of the Gradient
  • Context: Graduate
  • Thread starter Thread starter daudaudaudau
    Direction Gradient
The discussion revolves around understanding the concept of the gradient in relation to maximizing the rate of increase of a scalar function. Participants explore the mathematical foundations and implications of the gradient, particularly focusing on its direction and how it relates to the maximum rate of change.
  • One participant questions how to determine the direction of maximum increase as defined by the gradient.
  • Another participant suggests consulting standard sources for information on gradient calculation.
  • A participant asserts they understand the calculation but seeks clarification on why the gradient indicates the direction of maximum increase.
  • One participant explains that the gradient involves a dot product, noting that the cosine function is maximized when the angle is zero, which indicates the direction of maximum rate.
  • A later reply elaborates on the concept of the directional derivative, stating that the maximum rate of change occurs when the angle between the gradient and the direction vector is zero.
Participants express varying levels of understanding regarding the gradient and its implications, but there is no consensus on the initial question of how to determine the direction of maximum increase.
Some assumptions about the mathematical properties of the gradient and directional derivatives are present, but these are not fully explored or resolved in the discussion.
daudaudaudau
Hi. The book I'm reading says "We define the vector that represents both the magnitude and the direction of the maximum space rate of increase of a scalar as the gradient of that scalar". But how does one know in which direction the maximum increase is?
I suggest you consult standard sources to see how the gradient is calculated. Wikipedia is usually a good start.
I know how to calculate it. Then I guess my qustion is why the gradient is pointing in the direction of maximum increase.
gradient involves dot product, and cos is maximized when the angle is 0. That gives the direction for maximum rate.
Start from the directional derivative. grad(f)*u. This is equal to |grad(f)||u|cos(x), where x is the angle between them. This is maximum when cos(x) = 1 which occurs when x = 0. Implying that the maximum rate of change is in the direction of the gradient itself.
  • · Replies 16 ·
  • · Replies 18 ·
