Misconceptions in Calculating Power Dissipation in Electrical Circuits
The discussion revolves around calculating power dissipation in electrical circuits, specifically involving a generator supplying power through resistive cables. The original poster presents a scenario with a 100 kW generator, a potential difference of 10 kV, and a total cable resistance of 5 Ohms, leading to confusion regarding the correct method for calculating power dissipation.
  • The original poster attempts to calculate the supply current and power dissipated using different formulas, expressing confusion over discrepancies in results. Some participants suggest that the misunderstanding stems from misapplying the power equations and not accounting for the generator's limitations.
Participants are exploring the implications of using different power equations and the relationship between current, voltage, and resistance in the context of the generator's output. There is a recognition of the need to consider the generator's constraints in calculations, and some guidance has been offered regarding the correct approach to understanding power dissipation.
The original poster questions the validity of using the formula P = (V*V)/R in this context, indicating a potential misconception about the relationship between voltage, current, and power in the circuit setup. The discussion reflects on the limitations imposed by the generator's power output.
Gunman
A 100 kW generator supplies power at a p.d of 10kV through cables of total resistance 5 Ohms. Calculate the supply current and the power dissipated in the cables.
P = IV
V=IR
Q=It
Supply current:
P=IV
100 kW = (I)(10kV)
I=10A
Supply current 10 A.
But I get different answers when I try to find the power dissipated in the cable.
By using this formulae , P = (V*V)/R I get a huge number which is wrong because it is more than the power generated but when I use P = ( I * I ) / R , I get the correct answer.
Think I have a misconception about this [ P = (V*V)/R ] . Can someone tell me where I am wrong? and why so? Thanks in advance. =)
The power equation is P = I*I*R (sub in ohm's law into the power equation)
Yah I think he typo'd there. What he's missing is that power generator is FORCING a certain power output, and thus FORCING a certain current through that potential difference, which you found correctly
However if that power generator wasn't limiting you, you would have 10kV across 5 ohms, which corresponds to a current flowing of 2000amps, which when put into P=IV, doing 2000*10kV gives you the incorrect huge answer you got
by using P=V^2/R you're finding the power dissipated in 5ohm wires with a potential difference of 10kV, ignoring the fact that you're limited to 100kW from the power generator. By finding the actual current through the wires, you incorporate that
Ohh.Thanks blochwave! Understood why I was wrong. =)
  • · Replies 20 ·
