Can you feel the weight of a cloud as it flies over?
  • Context: Undergrad
  • Thread starter Thread starter lushsector9
    Flying Weight
The discussion revolves around the weight of clouds and whether one can feel the pressure change as a cloud passes overhead. Participants explore the measurement of cloud weight, personal experiences with clouds and fog, and the physics of buoyancy and air pressure in relation to clouds.
  • One participant mentions an article claiming the average weight of a cloud is equivalent to eight elephants and questions how to measure this weight given the non-uniform density and volume of clouds.
  • Another participant outlines a method for estimating cloud weight based on water droplet concentration and cloud volume, but acknowledges the difficulty in precise measurement.
  • A personal experience is shared where a participant did not feel any pressure change while riding through clouds, suggesting that clouds maintain pressure equilibrium with surrounding air.
  • One participant suggests that walking into a fog bank can provide a tangible experience of what a cloud feels like, as fog is essentially a cloud at ground level.
  • Another participant explains that the small water droplets in clouds are buoyant and held aloft by air pressure, arguing that this buoyancy is why one does not feel the weight of a cloud passing overhead.
Participants express varying views on the measurement of cloud weight and the sensation of pressure change when clouds pass. There is no consensus on whether one can feel the weight of a cloud or the pressure change associated with it.
Participants highlight limitations in measuring cloud weight due to non-uniform density and volume, as well as the challenges in experiencing pressure changes from clouds.
lushsector9
I once read an article that said the average weight of a cloud is equal to eight elephants. I know that they are very massive and even larger so they are not that dense knowing this I pose two questions... How would one measure the wieght of a cloud when the density/volume is not uniform nor is it constant nor? and theorectically would one be able to feel the pressure change as a cloud flew over (could you feel the weight of the clouds)?
No one can say exactly how heavy a cloud is. The way to measure its weight is this: they estimate the concentration of water droplet (very fine) then calculate the amount of water in cubic meter (or dm3 , cm3..). Then they have to estimate the whole volume of the cloud: the thickness, the widths.. And finally a multiplication.
For the second question: I can tell you my experience. Once I cruised in the high mountain area by motorbike, and there were times some cloud flew across the trails. I can not feel any difference in pressure, only cooler a bit. Theoretically, the cloud must retain certain pressure equilibrium with the surrounding air, so there musn't much difference.
Really, the easiest way to determine for yourself what a cloud feels like, without leaving the ground, is to walk into a fog bank. Fog, after all, is just a cloud at ground level.
That's one neat thing about living where I do. I can drive west, watching all of these honking huge clouds enveloping the mountains, and by the time I get to Banff or even Canmore, they aren't clouds any more; they're fog.
The water droplets in a cloud are very small, small enough to be, buoyant and held up in the sky by air pressure. The reason you wouldn't feel pressure from a cloud passing over you in the sky is because it's held up by the air pressure, not you. I suppose it might increase the local air pressure slightly, though I'm not sure if that's true, but the reason why you don't feel the eight-elephants-worth of pressure on you is the same reason you don't feel pressure from the weight of the floor above you when you're in a multi-story building: because that weight is being held up by something other than your body.
  • · Replies 25 ·
  • · Replies 28 ·
  • · Replies 21 ·
11K
