How high could you jump on a trampoline with increasing tension?
  • Context: High School
  • Thread starter Thread starter h.g.Whiz
    Trampoline
The discussion revolves around the effects of increasing tension in a trampoline on jump height, exploring various scenarios including single and double jumps, and the implications of human biomechanics and trampoline design. Participants consider both theoretical and practical aspects of trampoline physics.
  • Some participants propose that increasing tension could lead to higher jumps initially, but eventually the tension would resemble that of a flat surface, limiting height and potentially causing injury.
  • Others argue that increasing tension does not inherently increase jump height but rather increases the g-forces experienced during the bounce.
  • A participant suggests that energy must be pumped into the system to achieve higher jumps, indicating that tension alone is insufficient.
  • One viewpoint introduces the concept of resonance, where a trampoline could theoretically be adjusted to provide more acceleration during jumps, potentially increasing height.
  • Another participant discusses the idea of digging a hole under the trampoline to allow for greater displacement, suggesting this might enable higher jumps without injury.
  • Concerns are raised about the biological limits of the human body in response to increased stiffness and acceleration from a tightened trampoline.
  • Some participants mention the maximum jump height achievable under gravity, considering factors like wind resistance and terminal velocity, with references to competitive trampoline heights.
  • There are discussions about the design of competition trampolines and their efficiency compared to home trampolines, highlighting differences in air resistance and energy storage.
Participants express multiple competing views on the relationship between trampoline tension and jump height, with no consensus reached on the effectiveness or safety of increasing tension in this context.
Participants acknowledge various limitations, such as the biological response to increased forces, the role of energy input, and the impact of air resistance on trampoline performance. The discussion also highlights the complexity of the problem, with assumptions about ideal conditions and trampoline mechanics.
h.g.Whiz
suppose you had a trampoline that you could increase the tension in between jumps so that every time you landed. (and there is plenty of room between the surface and the ground) what would happen .what if someone double jumps then two people etc.. would your jump height keep increasing
it would increase to some extent, till the tension would be similar to jumping on a flat surface. it would most likely break at that point, assuming you made a big enough tension increase in one jump, otherwise, it would gradually decrease... that's not clear, is it?
You would eventually break a leg or something. Your body couldn't handle the extra stiffness of the springs. It would be like jumping off of a tall building and bouncing as you hit the ground.
Increasing the tension won't increase height, it just increase the g forces involved during the bounce. I'm not sure what you mean about two people, but one or more persons can provide the energy to bounce another person on a trampoline.
Exactly, you would decellerate, and accellerate quicker for each bounce, however, we all know what happens when you decellerate too quick.
The only way your jump height would increase is if you pumped energy into the system somehow. Increasing the tension doesn't change a thing about that.
If the trampoline resonated with you, meaning, just as you went up, it stiffened to give you more acceleration up, I believe then you would have a partial harmonic-oscillator. partial because it's not a continuous spatial displacement.
If then you loosened it as you fell to allow for more displacement, and tightened it again in the periodic fashion, you definitely could increase your height.
However, tightening it only does one thing: it increases the rate at which you decelerate and accelerate on the trampoline with the same displacement of the trampoline on landing.
A better way to achieve the same result without hurting yourself (provided that the springs are perfect, and you receive the same force upward that you do downward), is to dig a hole under the trampoline. Instead of increased acceleration through the tightened springs, the higher you bounce, the more displacement will occur in the springs, and you will get higher without hurting yourself. However, in reality, this will not work.
That would be correct assuming a rigid body. With biological systems, it's more complicated. IRL, the tighter membrane might make you react to avoid injuring yourself.
To get good height, start with more potential energy like jumping from above the trampoline onto it. Don't go crazy though. I've heard stories of kids who tried jumping from a tree onto a trampoline. Not good.
And where does the energy to tighten & loosen it come from?
Perhaps it could be possible to create a contraption that puts a plate at each end of the spring in which one plate is at a distance from the end that extends. When the spring then extends to a certain point, it would make contact with the plate and complete the circuit, in which the plates would then apply force to the ends of the springs causing more force upward from the trampoline before returning to their original position.
It would take a little work, but it doesn't seem like a hard thing to do.
I meant as a restricted version of the original problem, i.e. nothing but gravity supplies the original energy.
Rephrased: Is there a maximum jump height, if we have nothing but gravity, the trampoline, human and well, a surface for the trampoline to rest on?
Well, there is a maximum height considering we are taking into account wind resistance. Eventually as we all know, you will reach terminal velocity (if it is a perfect trampoline). When your speed does reach terminal velocity, the difference in height will depend on at which point in the trampoline's acceleration do you reach terminal velocity, and over time, that will be a constant point, and thus a maximum height.
A few web sites mention olympic competitors reach heights of 25 to 30 feet (top of head to the ground), which translates into an actual bounce height of 15 to 20 feet, with a trampoline that is 3.75 feet (45 inches) above the gym floor.
A competition trampoline "bed" is web made up of paired 1/8 inch diameter nylon chord, spaced about 5/8 inches apart, (called an "ozzie" bed, since an Australian manufacturer apparently made the first ones of this type), and is 7 feet wide by 14 feet long. There is very little air resistance on this type of trampoline bed, so the bounces are very elastic, not requiring a lot of energy. Former USA competition trampolines used 1/4 inch wide canvas strips instead of the nylon chords, and also had very little air resistance.
Home type trampolines typically have significant air resistance, and are not as energy efficient. Really old ones used canvas strips about 3/4 inch wide with about 1/4 inch wide holes. Outdoor trampolines use some type of black mesh which also has significant air resistance.
Youtube video from 2004 olympics:
Man that's crazy. I've been up on a utility pole at 30' above the ground, and that's scary. Though, I've also been at 60-feet as well which has a very nice view.
Right that's just monstrous. I guess the added energy comes from the trampoliner pushing their own weight, so to speak, adding to momentum and that gets stored + released by the trampoline. So it should be, in theory, possible to jump higher and higher and higher if you upped the tension each time (obviously G-forces would limit things somewhat).
30ft is just scary.
  • · Replies 33 ·
  • · Replies 16 ·
  • · Replies 16 ·
45K
12K
