What Makes a Marker Lid Fly Across the Room?
  • Context: High School
  • Thread starter Thread starter h.g.Whiz
The discussion centers on the mechanics of how a Crayola marker lid can be made to fly across a room when pressed against a smooth surface. Key factors include the pressure applied by the fingers, which flattens the lid, and the subsequent rebound effect that propels it upward. The rotation of the lid during flight is also considered, though the primary cause of lift-off is attributed to the release of pressure rather than the lid's rotational dynamics. Testing against a vertical surface further supports the idea that the launch mechanism is crucial for achieving flight.
  • Understanding of basic physics principles, particularly force and motion.
  • Familiarity with the mechanics of pressure and rebound effects.
  • Knowledge of rotational dynamics and its impact on object movement.
  • Experience with experimental methods to test hypotheses.
  • Research the physics of pressure and rebound in elastic materials.
  • Explore the principles of rotational dynamics and their effects on flight paths.
  • Conduct experiments on object launch mechanics using various surfaces.
  • Investigate the aerodynamics of small objects in motion.
Physics enthusiasts, educators demonstrating basic mechanics, and anyone interested in the dynamics of object motion and launch techniques.
h.g.Whiz
If you press your first three fingers evenly across a Crayola brand marker lid as hard as you can on a smooth surface, you can make it fly all the way across the room. I was wondering what causes it to take flight. I'm pretty sure its rotation has something to do with the way it floats through the air. But is the rotation actually creating the lift-off, or is it really just ricocheting of the floor.
You mean why it doesn't go straight across the table, but jumps into the air?
I suspect that the pressure on the cap flattens it. Release causes the cap to rebound, which would cause it to leap up.
If you want to prove that the cause is in the launch and not in the flight, do the same thing up against a vertical surface. The cap won't be able to fly, but I'll bet it will still leap straight up a foot or two.
  • · Replies 39 ·
  • · Replies 26 ·
  • · Replies 23 ·
  • · Replies 43 ·
