Which direction will the pencil fall
  • Context: High School
  • Thread starter Thread starter MathematicalPhysicist
    Direction Fall
The discussion revolves around the behavior of a pencil when released from a vertical position on a table, specifically exploring the direction in which it falls and the factors influencing this behavior. Participants examine concepts related to chaos theory, stability, and the conditions necessary for the pencil to remain balanced.
  • Some participants suggest that if conditions are kept the same, the pencil should fall in the same direction each time, although they acknowledge that achieving perfect conditions is practically impossible.
  • Others argue that the phenomenon is chaotic, where slight variations in initial conditions can lead to different outcomes, making the behavior unpredictable.
  • A participant questions whether a pencil can remain stationary on Earth without an external force, prompting discussion about the balance of forces acting on the pencil.
  • Some participants clarify that chaotic systems are not indeterminate but rather sensitive to initial conditions, which can be studied statistically.
  • There is a discussion about the feasibility of balancing a pencil with a sharp tip versus a dull one, with some arguing that ideal conditions would allow for balance regardless of sharpness.
  • One participant humorously references the tradition of balancing eggs on the equinox, suggesting a cultural aspect to the discussion.
Participants express differing views on the predictability of the pencil's fall and the nature of chaotic systems. There is no consensus on whether the pencil can remain balanced under ideal conditions, and the discussion remains unresolved regarding the implications of chaos theory in this context.
Participants note the challenges of maintaining ideal conditions in real-world experiments, including the effects of air currents and the precision required in releasing the pencil. The discussion also touches on the implications of quantum mechanics, such as the Heisenberg Uncertainty Principle, in relation to the experiment.
we have a pencil and you put the pencil with the spearhead of it downward (lets say in Earth and on a table), now you release your hand from the pencil to which direction will the pencil fall?
after a few experiments will the direction be the same as the first observation?
If you can keep the conditions the same throughout the series of experiments, it should fall to the same direction - if it falls at all. But you can't in real life, at least not with your hand. You can't possibly keep the pencil absolutely vertical to the table, and it's even harder to release the pencil with your fingers precisely the same way, every time.
I think it's a chaotic phenomenon: If the parameters governing one experiment is slightly different from those governing the second experiment, the fall direction might alter appreciably.
i thought to name this thread pencils and chaos (but because lack of full understanding of chaos didnt).
btw i might be wrong but isn't a chaotic phenomon is a situation where the initial conditions are the same (more or less) but the result is different therefore you can't predict it's behaviour.
just one thing to clear, can a pencil in Earth (with it's g) not fall at all?
how can this event happen without an outside force (besides the force acting on it from the centre of Earth and the friction with the air) acting on it?
It is the "more or less" sameness both Chen and I pointed out; the behaviour of a chaotic
system is not "indeterminate".
With "indeterminate" I mean the impossibility of setting up an initial-value problem where a unique solution exists; that is, whatever choices of parameters you make, you necessarily have an ill-posed problem.
In practice, I believe chaotic systems are studied by statistical means; i.e. calculating
probabilities of various outcomes.
The other force is the support force (aka "normal" force) from the table. If you can get the pencil's center of mass to be positioned perfectly above the point of contact between pencil point and table, then the two forces will balance, and there will be no torque. This is possible, and it gets easier when the point is not so sharp.
BTW, take any dozen eggs, on any day of the year (enough with this equinox BS) you should be able to balance most of them on their ends on a flat table. Most people just assume its impossible, but with enough patience, (and no air currents) you can balance anything.
Haha, don't you love those people that gather around in parks on the equinox day and play with eggs? :-p I wonder what the origin is of this tradition.
Chaotic systems are ones with an incredibly sensitive dependence on initial conditions, so a small change dx in starting posistion could make a very appreciable change x in final posistion.
what's the point in the experiment if not to give the ideal conditions and one of them is that the pencil's point is as sharp as it can be.
it's easy to balance the pencil when the point isn't that sharp (because of the surface of the point) but what about a sharp pencil (as sharp as it can cut you :cool: )?
As you go from a "dull" pencil to a sharper and sharper tip, you go from "real" world to "ideal" world. If you're going into "ideal" sharpness (tip is one single atom of carbon), then you have to also allow other ideal conditions. THerefore, the balancing of the pencil becomes no less possible at ideal extremes, since you would "ideally" still be able to get the canter of mass positioned directly over the single atomic point of contact. Ideally there would be no air currents, the table would be perfectly flat and perfectly smooth, and there would be no other forces acting on the pencil.
Certainly, someone will bring on the HUP, but the uncertainty of position of the center of mass would, I'm sure, be much smaller than the size of the carbon atom at the tip of the pencil. DO correct me if I am wrong.
what's the point... ?
Ha Ha, I get it.
  • · Replies 19 ·
  • · Replies 16 ·
9K
  • · Replies 0 ·
