Thread Closed
Vacuum chamber
Share Thread
Jan11-08, 04:20 AM   #1
Vacuum chamber
Hello, I'd like to propose you one question.
I tried to use my logic but it doesn't work.
I have a chamber and i make the vacuum in the interior of it. I have one inlet pipe and two outlet pipes, there is one substance that is coming in, the reaction inside the chamber and the two exits for the two products that they were produced in the reaction.
I'd like to know if this is possible. I mean, I want the less possible pressure in the interior, and can I do this? put one substance into and out normally?
Thank you very much
PhysOrg.com physics news on PhysOrg.com
>> Cheap, color, holographic video: Better holographic video displays
>> First entanglement between light and optical atomic coherence
>> EUROnu project recommends building Neutrino Factory
Jan11-08, 06:24 AM   #2
Recognitions:
Gold Membership Gold Member
What kind of reaction are you refering to? Since you only have one inlet you are presumably not talking about a reaction resulting from "mixing" two gases.
Otherwise, I can't see why it wouldn't be possible. You need one pump for circulating the gases and another for the differential pumping of the chamber.
Jan11-08, 06:34 AM   #3
Hi,
Actually the chamber I speak about it's a drying chamber of a spray dryer. It's a device to dry particles. There are one mix of product and water, we atomize it in small droplets (always inside the room) and with dry air (I forgot one another inlet pipe, the air to dry) we put the water off the mix. That's what happens inside the chamber.
I doubt because I need special devices in the inlet and outlet pipes and as I have the lower pressure inside the chamber and atmospheric pressure in the pipes I don't know if it is possible.
Thanks
Jan11-08, 07:22 AM   #4
dst
Vacuum chamber
Yes it's possible. You have your reactant going in, and pressure in the chamber can be controlled via the outlet in a manner similar to vacuum filtration.
The only thing is that pressure of the inlet will increase to attempt to balance out the low pressure in the chamber.
Jan14-08, 03:48 AM   #5
Ok, i understand.
Thank you, you have helped me very much.
Thread Closed
Similar discussions for: Vacuum chamber
Thread Forum Replies
Inflationary vacuum and the true vacuum Cosmology 17
Do vacuum fluctuations contribute to vacuum polarization High Energy, Nuclear, Particle Physics 2
Vacuum to Vacuum Amplitudes and Functional Integrals Quantum Physics 9
Centrifugal force for supporting vacuum chamber walls? General Physics 17
Does a Vacuum Cleaner work inside a Vacuum? General Physics 12
