How to derive radius ratio and calculate reaction energy
This discussion focuses on deriving the minimum radius ratio for coordination numbers 4 and 6, as well as calculating the reaction energy for the polymerization of styrene (C3H6). The reference book is "Introduction to Materials Science for Engineers" (6th edition) by James F. Shackelford. The calculation of reaction energy involves using bond dissociation energies to determine the energy required to break and form bonds, with the formula for enthalpy being the energy used to break bonds minus the energy gained from formed bonds.
  • Understanding of coordination chemistry and radius ratios
  • Familiarity with bond dissociation energies and their tables
  • Basic knowledge of polymer chemistry and reaction mechanisms
  • Proficiency in thermodynamics, specifically enthalpy calculations
  • Study the geometry of coordination compounds to derive radius ratios
  • Research bond dissociation energy tables for various carbon bonds
  • Learn about polymerization mechanisms and energy calculations
  • Explore thermodynamic principles related to enthalpy and reaction energy
Chemistry students, materials scientists, and chemical engineers involved in polymer chemistry and thermodynamic calculations.
aznkid310
Greetings all,
My first problem: I have been asked to derive the minimum radius ratio for coordination numbers 4 and 6. I read the book and looked at the sample problems, but they do not help at all. I realize that it has to do with the geometry of it, but have no idea how to use that.
The book is:
INTRODUTION TO MATERIALS SCIENCE FOR ENGINEERS (6th edition) by James F. Schackelford.
My second problem: How does one calculate the rxn energy for polymerization of styrene (C_3H_6). We are given various bond energies for single carbon - carbon bonds at different lengths. I drew it and looks like: c - c = c w/ H atoms around it. In an example, the picture is: c = c and they broke it down into 2(c - c). how would i do it for 3 carbons? Also, how would I know what the bond length is (since the bond energies are related to them)?
Does rxn energy=enthalpy? If so, you need a table of bond dissociation energies, which tell you how much energy it takes to break different kinds of bonds. Then look at the reaction and see which bonds were broken and which were formed. Enthalpy equals the energy used to break the bonds plus the energy gained by forming the new bonds. So enthalpy=broken minus formed.
I'm not sure how bond length would be required to solve the problem, but that information should be available in a table somewhere.
But I'm no engineer, so chances are the problem is more complicated than this.
