| Thread Closed |
Magnitude and Direction of Electric Fields |
Share Thread | Thread Tools |
| Jan11-08, 09:37 PM | #1 |
A small object A, electrically charged, creates an electric field. At a point P located 0.250m directly north of A, the field has a value of 40.0N/C directed to the south. A) 1.11×10^−9C B) −1.11×10^−9C C) 2.78×10^−10C D) −2.78×10^−10C E) 5.75×10^12C F) −5.75×10^12C What is the charge of object A? 2. Relevant equations E = (KQ)/r^2 3. The attempt at a solution After manipulating the above equation, I found out that the charge Q = (E*r^2)/K Q = (E*r^2)/K = (40*(0.25^2))/9×10^9 = 2.78×10^−10C makes sense to me, but should it be negative or positive? |
| Jan11-08, 10:16 PM | #2 |
Recognitions:
| Jan11-08, 10:20 PM | #3 |
A way to remember the rule that dynamicsolo stated is to recall that E fields are defined in terms of the force felt by a unit test charge, which is positive by assumption. That gives the directions stated above.
| Jan11-08, 10:24 PM | #4 |
Recognitions:
| Jan11-08, 11:57 PM | #5 |
so it would be positive?
| Jan12-08, 12:21 AM | #6 |
Recognitions:
| Jan12-08, 07:53 AM | #7 |
cse63146 - Think it through in these steps:
- Is the test charge (i.e. field point in question) North or South of the field source at A? - Given that location, does the direction of the force it feels indicate an attractive or repulsive force? - Considering that the test charge is defined to be positive, what does your previous answer tell you about the sign of the source charge at A? |
| Jan12-08, 09:28 AM | #8 |
Since there's a point P north of charge A, and the electric field is directed to the south (towards the charge), it looks like it's inward, which makes the charge negative?
| Jan12-08, 11:58 AM | #9 |
Recognitions:
| Jan12-08, 12:25 PM | #10 |
There's a part B of the question which only showed up after you answer part A.
If a second object B with the same charge as A is placed at 0.250m south of A (so that objects A and B and point P follow a straight line), what is the magnitude of the total electric field produced by the two objects at P? I know that E = (KQ)/r^2 so E = (KQ)/r^2 E = ((9×10^9)(2.78×10^−10)/0.5^2 E = 10 So the total magnitude produced by the two objects 10 + 40 = 50N/C? |
| Jan12-08, 12:34 PM | #11 |
| Jan12-08, 12:42 PM | #12 |
Got both questions right. Thank you all.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Magnitude and Direction of Electric Fields
| Calculating Electric Field Magnitude and Direction | Advanced Physics Homework | 6 | ||
| Magnitude and direction of electric field | Introductory Physics Homework | 0 | ||
| Magnitude & Direction of electric fields? | Introductory Physics Homework | 4 | ||
| Magnitude and Direction of Electric Field - Question | Introductory Physics Homework | 11 | ||
| magnitude and direction of electric force (file attached) | Introductory Physics Homework | 6 | ||
