How Do You Calculate the Rotational Inertia of a Composite Object?
The discussion focuses on calculating the rotational inertia of a composite object consisting of a circular hoop and a square made of four thin bars. The circular hoop has a radius of 0.50 m and a mass of 3.0 kg, while each bar of the square also has a mass of 3.0 kg. The relevant equations for rotational inertia include I of point mass = mr², I of hoop = mr², and I of rod = 1/3 mr². The user struggled to combine the rotational inertia of the hoop and the rods correctly to find the total inertia about the vertical axis of rotation.
  • Understanding of rotational inertia concepts
  • Familiarity with the equations for point mass, hoop, and rod inertia
  • Basic knowledge of composite objects in physics
  • Ability to visualize and analyze rigid body rotation
  • Calculate the total rotational inertia of the composite object using I of hoop and I of rods
  • Explore the effects of changing mass and radius on rotational inertia
  • Learn about parallel axis theorem for composite objects
  • Investigate real-world applications of rotational inertia in engineering
Students studying physics, particularly those focusing on rotational dynamics, as well as educators seeking to explain composite object inertia calculations.
dari09
Rotational Inertia Problem--PLEASE HELP!
Figure 12-39 shows a rigid structure consisting of a circular hoop, of radius R and mass m, and a square made of four thin bars, each of length R and mass m. The rigid structure rotates at a constant speed about a vertical axis with a period of rotation of 1.0 s. Assuming R = 0.50 m and m = 3.0 kg, calculate the structure's rotational inertia about the axis of rotation
The figure is attached
I of point mass = mr^2
I of hoop = mr^2 or .5mr^2
I of rod = 1/3 mr^2
I tried to add the I of the hoop and two of the rods together (because the other two rods are parallel to the rotating axis) but nothing that I've tried really worked...
http://panda.unm.edu/Courses/Price/Phys160/p27-2.pdf"
  • · Replies 19 ·
  • · Replies 28 ·
  • · Replies 16 ·
