| Thread Closed |
[SOLVED] Integration of Inverse of f(x) |
Share Thread | Thread Tools |
| Jan13-08, 05:11 AM | #1 |
[tex]\int\frac{1}{y^{4}-6y^{3}+5y^{2}}[/tex] dy =
[tex]\frac{1}{4y^{3}-18y^{2}+10y}[/tex](ln|[tex]{y^{4}-6y^{3}+5y^{2}}[/tex]|) is this correct way or doing it? thanks. i was a bit of confuse, if i should do it the above or partial fraction the denominator it? thanks |
| Jan13-08, 05:26 AM | #2 |
Recognitions:
yes, factorise and then partial fractions is ok
| Jan13-08, 05:28 AM | #3 |
wait a minutes,i show my partial fraction. please point out where gone wrong ;) thanks
| Jan13-08, 05:32 AM | #4 |
Recognitions:
firstly you can further factorise y^2-6y+5
| Jan13-08, 05:33 AM | #5 |
[tex]\frac{1}{y^{4}-6y^{3}+5y^{2}}[/tex]
=[tex]\frac{1}{y^{2}(y^{2}-6y+5)}[/tex] =[tex]\frac{1}{y^{2}(y-1)(y-5)}[/tex] So, by Partial fraction, is this correct? [tex]\frac{1}{y^{2}(y-1)(y-5)}[/tex] =[tex]\frac{A}{y}[/tex]+[tex]\frac{B}{y^{2}}[/tex]+[tex]\frac{C}{y-1}[/tex]+[tex]\frac{D}{y-5}[/tex] and then, by comparing coefficient of y^3, y^2, y. (A+C+D){y^{3}}=0 (-6A+B-5C-D){y^{2}}=0 (5A-6B)y=0 answer is A=6/25, B=1/5, C=3/10. D=-87/50. but doubt my answer. anyone can point out?thanks |
| Jan13-08, 05:34 AM | #6 |
| Jan13-08, 05:35 AM | #7 |
Recognitions:
I can tell you the answer....
![]() no need use latex for such simple expression most likely you have treated the y^2 bit incorrectly |
| Jan13-08, 05:42 AM | #8 |
after i substitute A,B,C,and D.
i can get back my original 1/f(x) |
| Jan13-08, 05:43 AM | #9 |
Recognitions:
looks ok so far
| Jan13-08, 05:44 AM | #10 |
| Jan13-08, 05:48 AM | #11 |
Recognitions:
FYI i've got
A=6/25 B=1/5 C=-1/4 D=1/100 |
| Jan13-08, 05:48 AM | #12 |
[tex]\frac{1}{y^{2}(y-1)(y-5)}[/tex]=[tex]\frac{6}{25y}[/tex]+[tex]\frac{1}{5y^{2}}[/tex]+[tex]\frac{3}{10(y-1)}[/tex]-[tex]\frac{87}{50(y-5}[/tex] |
| Jan13-08, 05:50 AM | #13 |
| Jan13-08, 05:59 AM | #14 |
| Jan13-08, 06:08 AM | #15 |
6/25(ln|y|)-1/4(ln|y-1|)+1/100(ln|y-5|)-1/(5y). right? but this problem is actually make y the subject in this equation, how to go about it further? [tex]\int\frac{1}{y^{4}-6y^{3}+5y^{2}}[/tex] dy = [tex]\int\[/tex] dt the original question is [tex]\frac{dy}{dt}[/tex]=[tex]y^{4}-6y^{3}+5y^{2}[/tex] find y(t). if [tex]\int\frac{1}{y^{4}-6y^{3}+5y^{2}}[/tex] dy = 6/25(ln|y|)-1/4(ln|y-1|)+1/100(ln|y-5|)-1/(5y) then i m stuck to make y the subject. anyone to point out the mistake.thanks |
| Jan13-08, 06:14 AM | #16 |
anyone, can show me the right way?
| Jan13-08, 06:32 AM | #17 |
another differential eq. question.
y'=1+xy find y. how to go about it. i m clueless my method of multiply dx to (1+xy) doesn't work in this case. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: [SOLVED] Integration of Inverse of f(x)
| integration of inverse root | Calculus & Beyond Homework | 15 | ||
| Integration of inverse function | Calculus | 8 | ||
| [SOLVED] Integration of Inverse Tangent Function | Calculus & Beyond Homework | 3 | ||
| Inverse of Integration? | Calculus | 3 | ||
| Is Integration the inverse of differentiation? | Introductory Physics Homework | 11 | ||
