Thread Closed
Increase gas pressure in unchanged volume
Share Thread Thread Tools
Jan13-08, 11:06 AM   #1
wli
Situation:
Start pressure: p1=1 bar;
Volume: V=36m3;
Temp.: T1=T.
Now I need to increase the pressure to 6 bar, but the volume remains unchanged. So:
End pressure: p2=6 bar;
Volume: V=36m3;
Temp.: T2=T.
So volume and temperature remain unchanged.
What amount of gas (m3) do I need to add to increase the pressure with 5 bar (p2-p1).
Compressor gives 185 l/s, max. working pressure is 7 bar.
I know p*V/T=p*V/T but I'm struggling to calculate the required volume.
Werner
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jan13-08, 12:46 PM   #2
Recognitions:
Homework Helper Homework Help
You haven't given any calculations of your own. Anyway, think of the ideal gas law in its exact form. I hope you are right about the two temps being the same.
Jan13-08, 12:57 PM   #3
Best Humor 2012
Recognitions:
Gold Membership Gold Member
Quote by wli View Post
Situation:
Volume: V=36m3;
Temp.: T1=T.
Volume: V=36m3;
Temp.: T2=T.
Werner
Try ignoring the numbers for the compressor and imagine the container only.
Jan14-08, 12:11 PM   #4
Any calculations you make will have to take into account STP or Standard Temperature and Pressure. You also have to know that to raise the pressure in a fixed volume container will also raise the temperature. But then after you have raised the pressure, and the temp went up with it, the pressure will drop as you let the compressed gas cool to the original temp. The whole thing is a dynamic system in which changing any one factor will change the other two.
First you have to understand STP so follow this first link for a tutorial.
http://searchcio-midmarket.techtarge...539342,00.html
Converting all calculations to STP after the fact gives you a basis to make comparisons.
Another helpful tutorial is the one on an "Ideal Gas" and you can find it at the next link
http://hyperphysics.phy-astr.gsu.edu...ic/idegas.html
Finally you are missing one factor in your question and that is the term "mole" which refers to the absolute quantity of gas in any fixed volume system at any temperature and pressure.
The next link is to a calculator to allow you to figure out all the info you needto know to achieve your goal.
http://www.1728.com/stp2.htm
Thread Closed
Thread Tools
Similar Threads for: Increase gas pressure in unchanged volume
Thread Forum Replies
increase pressure in closed container Classical Physics 20
Thermodynamics: Amount of work required to increase pressure at constant volume Introductory Physics Homework 6
Isothermal increase in pressure of solids Advanced Physics Homework 2
how we increase the pressure of a air compressor Engineering Systems & Design 4
increase in mass & decrease in volume? Special & General Relativity 9
