Force exerted by the floor on the feet of a student doing pushups
  • Thread starter Thread starter PhysicsPhun
    Force Student
The discussion revolves around calculating the force exerted by the floor on a student's feet while performing pushups. The problem involves concepts of torque, equilibrium, and forces acting on a body in a static position.
  • The original poster attempts to determine the pivot point for analyzing the forces and torques involved. There is uncertainty about how to calculate the effective mass of the feet and how to apply torque principles correctly.
  • Some participants suggest treating the student as a plank with two supports (feet and hands) and applying equilibrium conditions to solve for the normal forces.
  • One participant proposes using the hands as a pivot point to set up the torque equation, leading to a calculation of the force on the feet.
Participants are exploring different methods to approach the problem, with some providing guidance on using torque and equilibrium principles. The discussion includes attempts at calculations, but there is no explicit consensus on the final answer, as one participant expresses satisfaction with their result while others continue to engage with the problem.
The problem is constrained by the assumption of neglecting friction and the need to determine forces based on static equilibrium conditions. There is also ambiguity regarding the effective mass distribution between the feet and hands.
PhysicsPhun
A physics student is about to do a pushup. Her center of mass lies above a point on the floor which is d1 = 1.01 m from her feet and d2 = 0.65 m from her hands. If her mass is 45.0 kg, what is the magnitude of the force exerted by the floor on her feet? (Neglect friction in this problem)
I don't think i know where to put the pivot in this problem. I tried a few times at the center of gravity.
Also I don't know what the "mass" of her feet are is it just (1.01/1.66)*45?
That's what i did then, once i just tried to find the Normal force with just that.
The next time I tried , I used the same method with the "mass" of her feet and hands, and then tried to find the torques. Her feet had a larger torque, so I subtracted the torque of her hands, and then divided by 1.01 to try and find the Normal force against her feet.. That didn't work either..
Anyone have a better approach?
Just treat her like a plank of wood with two supports: feet and hands. Each support will have a normal force pushing up to counter her weight pulling down (at her center of mass). For equilibrium, the sum of the torques must equal zero. You can solve it in one step if you choose her hands as your pivot point.
So, Hands are Pivot.
Weight of girl*distance from pivot = F* distance of feet from pivot
45*9.8*.65 = (1.66)F
F=286.65/1.66
F of feet = 172.68
Only one shot left for right answer.. Does that look good?
Yay: )
I got it Thanks!
  • · Replies 21 ·
  • · Replies 35 ·
