Solving Thermodynamic Problem: Outlet Temp of Pipe Carrying Water
  • Thread starter Thread starter rippir
    Thermodynamic
The discussion focuses on calculating the outlet temperature of water flowing through a pipe, specifically a 5m long and 0.02m diameter pipe, given an inlet temperature of 40 degrees Celsius, a flow rate of 3 m/s, and an ambient temperature of 20 degrees Celsius. The problem is identified as a convection heat transfer issue, emphasizing the importance of assumptions in heat transfer calculations. Participants recommend consulting an undergraduate heat transfer textbook, particularly the section on convection heat transfer, to understand the principles involved.
  • Understanding of convection heat transfer principles
  • Familiarity with fluid dynamics and flow rates
  • Basic knowledge of thermodynamic concepts
  • Ability to interpret and apply formulas related to heat transfer
  • Study the convection heat transfer section in an undergraduate heat transfer textbook
  • Research the effects of flow rate on heat transfer in pipes
  • Learn about fully developed flow conditions in fluid dynamics
  • Explore HVAC system design principles related to pipe length and temperature changes
Students and professionals in mechanical engineering, HVAC system designers, and anyone involved in thermal management and heat transfer calculations.
rippir
Hi,
after a while of searching through a thermodynamics book and not really finding what I'm looking for I come to you all with my problem :D
Here it is:
I am required to write a formula which will allow me to determine the outlet temperature of a pipe carrying water for any given flow rate, diam, length, inlet temp, ambient temp.
So for a sample problem, if water enters a 5m long 0.02m diameter pipe at 40 degrees C & travels through the pipe @ 3 m/s and the ambient temperature is 20 degrees C, what temperature will the water at the outlet be?
For the time being, I would like to assume that the pipe which the water is flowing through is constantly 20 degrees due to ambient temperature.
The purpose of this problem is to know how long a pipe in a HVAC system can be before the water reaches ambient temperatures
Any help is greatly appreciated.
Cheers!
Daniel
This sound like a heat transfer problem and specifically convection heat transfer. As always with heat transfer problems the trick is in the assumptions you could assume the pipe to naturally convect into the ambient air but this seems overkill. Just pick up a undergraduate heat transfer book and go to the convection heat transfer section. Remember that the flow might not be fully developed at the entrance (although you might get away with assuming this).
This is not a problem that is typically described in a thermodynamics book!Let me know if you run into specific problems.
yes i agree
14K
  • · Replies 31 ·
