MOS capacitor transient response
The discussion centers on the transient response of a MOS capacitor with an n-substrate when subjected to step bias voltage changes. Specifically, when the bias shifts from -0.3 volts to -0.6 volts, the depletion region widens, and the time taken to reach a new steady state is influenced by the charge carrier dynamics. The response time can be modeled using an exponential approach, as indicated by the equation derived from experimental studies, where the time constant is determined by the device's dimensions, field-effect mobility, and final gate voltage.
  • MOS capacitor theory
  • Charge carrier dynamics in semiconductors
  • Field-effect mobility concepts
  • Understanding of exponential functions in physical systems
  • Research the time constant formula for charge density in MOS capacitors
  • Study the effects of gate voltage swings on charge carrier density
  • Explore noncontact scanning potentiometry techniques for real-time monitoring
  • Investigate the impact of device dimensions on transient response in MOS capacitors
Electrical engineers, semiconductor physicists, and students studying MOS technology will benefit from this discussion, particularly those focusing on transient response and charge dynamics in semiconductor devices.
hasib_eee
Hello.
Suppose we have a MOS capacitor (n-substrate). When we give negative voltage the majority carrier (electrons) are repelled from the oxide-substrate interface and move towards the bulk.
Say the bias is -0.3 volts. The substrate is depleted and in steady-state. Suddenly if the bias is changed from -0.3 to -0.6, I know that the width of depletion region will increase definitely.
My question is how long will it take to reach the new steady state? Does it depends on some form of life time or response time? I found typical example in textbooks for optical step excitation where they showed (1-exp(t/tao)) like shape to reach steady-state.
How can I model the movement of majority carriers (electrons) under step bias?
Please give me some information.
Thanks.
M. Satter.
Hi hasib_eee,
I think I may have found an article that answers (to a certain degree) your question. Among the test conditions were step like bias voltages. I assume that your school gives you free access to various scientific journals. Here is the abstract:
We present an experimental study of charge transfer in polymer thin-film field-effect devices. The rearrangement of the charge-carrier density in the transistor channel upon a gate-voltage swing has been monitored in real time and space by means of noncontact scanning potentiometry. The experimental results are in excellent agreement with a simple theory, in which the charging currents are assumed to be driven by drift in the self-induced electric field. The charge density exponentially approaches its final value with a time constant given by L2/µ|Vg|pi2, where L is the characteristic device dimension, µ the field-effect mobility, and Vg the final gate voltage.
See:
L. Bürgi, R. H. Friend, and H. Sirringhaus. Applied Physics Letters; 3/3/2003, Vol. 82 Issue 9, p1482, 3p
11K
17K
