New Reply
Ship launching
Share Thread Thread Tools
Jan15-08, 09:16 PM   #1
Ship launching
Hi!
I saw from youtube clips that dry dock ship launching use these wooden(?) contraptions. Do they cause damage to the paint coat of the ships?
Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Jan15-08, 09:49 PM   #2
Recognitions:
Homework Helper Homework Help
No thats why you use wood.
The boats don't generally slide on the wood, the sit on cradles that slide on greased rails.
Jan16-08, 01:00 AM   #3
Quote by mgb_phys View Post
So you are saying that there is not a slightest damage to the coating in all cases?
Thanks
Jan16-08, 03:03 AM   #4
Mentor
Ship launching
Quote by Kramjit View Post
Thanks
What do you propose that they use to cause LESS damage?
Jan16-08, 04:54 AM   #5
Perhaps we could use a material with low coefficient of friction as a material for the ramp, as described by Mr./Mdm mgb_phys. Eliminate also, altogether, the use of grease.
Fundamentally, I just would like to know if existing methods scratch the paintwork.
Thanks
Jan16-08, 07:23 AM   #6
Recognitions:
Gold Membership Gold Member
It's been over 30 years, but when i had some involvement with boat building(intracoastal, and river pushboats) the below waterline coatings, were mixes of paints and resins, and some flourlike metals, that had to be continually stirred with a air motor while in the paintpot.
These finishes, when cured, were as hard or harder than the metal they covered.
Not sure but i would think that finishes today might be even better.
Dec27-11, 03:06 AM   #7
It is an old topic I know.
For ship launching the most interesting method is air bag launching which has the least demand of ramp and related instruments.
The force analyse during airbag ship launching is very complicated because each airbag's bearing force will change in the process. According to Calculation Result from Eversafe Marine, the pressure of some airbags will double in the launch.
So it is important to control airbag initial pressure before launch.
Jan7-12, 08:22 PM   #8
I was wondering if airbag launching may cause the vessel bottom painting damage since there will be relative motion between air bags and vessel during their movement.
Jan8-12, 02:29 AM   #9
According our experience, airbag launch doesn't cause any damage of bottom painting unless the painting is not dry enough.
When air bags roll with vessel the friction force will impact on painting but can not peel it off.
In some extreme condition we really found painting was scratched by air bags. See that Danube salvage project , airbags were intent to get out of vessel bottom, they rub the bottom at all times because the unbalanced force. So painting was somewhat scratched.
In normal launching, this never happen.
Mar8-12, 12:34 AM   #10
thanks for your explanation. I visited your website and found some interesting info. As a civil engineer ,i am wondering the structure launch with air bags,such as cocrete caisson,steel cofferdam,etc. So how much weight can be launched with your bags? Is there any limitation of weight or dimension?
Mar8-12, 08:14 PM   #11
Mike, you are welcomed. Structure airbag launching is a very prosperous application in China. The heaviest caisson we have launched with bags are 5600 tons. The limitation of air bag launch is not only decided by structure dimension or weight but also the launch ramp and water level. With good launch condition, possible launch weight by air bags can reach 8,000-10,000 tons, we think. You may see some projects did by our engineering team:
Steel cofferdam launch with marine air bags
Caisson air bags transportation project
New Reply
Thread Tools
Similar Threads for: Ship launching
Thread Forum Replies
marker lid launching General Physics 1
Launching a UAV.... Mechanical Engineering 4
Projectile Launching Introductory Physics Homework 4
Launching device Mechanical Engineering 0
launching a ball on a ramp Introductory Physics Homework 1
