How can I efficiently build a boomilever using only wood and glue?
  • Thread starter Thread starter backdoor
    Build
This discussion focuses on constructing a boomilever using only wood and glue, adhering to specific dimensions and material restrictions. The boomilever must utilize wood pieces no larger than 1/4 inch in height and width, with dowels capped at a 1/4 inch diameter. The attachment base dimensions are limited to 30cm x 20cm and 1/2 inch thick, requiring careful design to ensure compliance with these specifications. Participants are encouraged to research existing threads for foundational knowledge before seeking further assistance.
  • Understanding of structural engineering principles related to tension and compression.
  • Familiarity with woodworking techniques and tools.
  • Knowledge of different types of adhesives and their properties.
  • Experience with basic design and modeling concepts for load-bearing structures.
  • Research effective wood joint techniques for enhanced strength.
  • Explore the properties of various adhesives suitable for wood bonding.
  • Study the principles of load distribution in beam structures.
  • Investigate previous boomilever designs for inspiration and efficiency tips.
This discussion is beneficial for high school students participating in engineering projects, educators guiding students in practical applications of physics, and hobbyists interested in structural design and woodworking.
backdoor
Hi,
I am a high school student and for a class projecI have to build a boomilever. Except for the atachment base I can only use wood and glue. Any type of glue can be used. Inculding gussets, it must be constructed of wood no longer than 1/4 inch high and 1/4 inch wide in cross-section. If dowels are used, they may not have a diameter greater than 1/4 inch. There is no limit on the length of idividual wood pieces used in the construction.The entire attachment base may not exceed 30cm x 20cm 1/2 inch thick and permanently attached to boomilever. When mounted to the testing wall no part the of the attachment base may extend farther than 1/2 inch from the wall.
I would greatly appreciate help/tips on building this boomilever, this is my first time and i will be graded on efficiency.
First, do a quick search. There have been a few threads already on this topic. See where that takes you and then come back with more questions.
  • · Replies 59 ·
  • · Replies 42 ·
31K
  • · Replies 42 ·
9K
