Why a magnetic flux in closed surface area is always 0?
The discussion revolves around the concept of magnetic flux through a closed surface, exploring why it is always considered to be zero. Participants examine this topic through various lenses, including theoretical implications, comparisons to electric fields, and analogies with phenomena like Faraday's cage.
  • Some participants apply Lenz's law to argue that charges on a spherical hollow surface move to oppose the magnetic field, resulting in cancellation of flux.
  • There is a comparison made between magnetic flux and gravitational effects, though the relevance is not fully explored.
  • One participant mentions Gauss' Law for Magnetism, stating that it implies the absence of magnetic monopoles, which leads to zero net flux through a closed surface.
  • Another participant questions the behavior of magnetic flux in stationary versus non-stationary fields, seeking clarification on whether the net flux remains zero in both cases.
  • Some participants discuss the nature of magnetic flux lines, suggesting that they form closed loops, which contributes to the net flux being zero.
  • There is a distinction made between magnetic flux and electric flux, particularly in the context of Faraday's cage, where electric charges realign to cancel external fields.
  • One participant expresses confusion about how magnetic flux can be zero when a magnetic field exists, leading to further clarification that it is the net flux that is zero, not the magnetic field itself.
  • Another participant raises a question about the behavior of magnetic fields in relation to permanent magnets and their interaction with conducting loops.
Participants exhibit a mix of agreement and disagreement. While some concepts, such as the application of Gauss' Law for Magnetism, are accepted, there are varying interpretations and questions regarding the implications of magnetic flux in different contexts, particularly concerning stationary versus non-stationary fields and the analogy with electric fields.
Participants express uncertainty about the implications of magnetic flux in non-stationary fields and the relationship between magnetic flux and electric fields, particularly in the context of Faraday's cage. There are also unresolved questions regarding the behavior of magnetic fields in relation to permanent magnets.
Physicsissuef
Apply Lenz' law to a spherical hollow surface, all the charges move to oppose the magnetic field and each other and it all cancels out.
Compare with gravity...
Do you have some diagram or picture?
Hmmm dst, can you explain this further? This is very similar to how the Faraday's cage works right?
the E field entering the close surface is equal to the E field exiting the close surface ;)oops, it should be magnetic flux instead of e field
This is one of Maxwell's equations. It essentially says that there are no magnetic monopoles (only dipoles, which give no net flux through any surface surrounding them). See: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/maxeq2.html#c2"
Contrast this with Gauss's law for electric fields. No problem getting a non-zero electric flux through a closed surface--just have it enclose a net charge.
I saw that law, but still can't understand what is happening inside the closed surface.
0 magnetic flux, is 0 times the magnetic field is perpendicular to the area or what? As I know Gauss' law for Magnetism is different for electric fields. In case of electric fields, it is not zero.
The net magnetic flux through a closed surface is zero. Magnetic flux is defined and illustrated here: http://hyperphysics.phy-astr.gsu.edu/Hbase/magnetic/fluxmg.html"
In the case of STATIONARY fields, the magnetic flux through a closed surface is definitely zero.
And what about non-stationary fields? Is it still zeroing?
PS
I am so lazy to take integral... maybe anybody already knows the answer? :confused:
Yep. Maxwell's equations still hold.
Does it help to think about the fact that lines of magnetic flux are always closed loops (since there are no monopoles for them to begin or end on)? You can't draw a closed loop that intersects a closed surface at only one point; it goes in at one point and out at another - i.e. number of "innies" = number of "outies", hence zero net flux.
Does it have something with the Faraday's cage?
Not really - as stated in a previous post, the lines of electric flux do not have to total zero through a closed surface. The Faraday cage has more to do with charges in the cage realigning themselves to cancel the contained field. It works only with an electrically conductive closed surface; it's not true for just any mathematical closed surface, as it is for the case of the magnetic flux through a closed surface.
But isn't the magnetic flux, a magnetic field perpendicular to some area? How is possible that the magnetic field is 0, when still it exists?
You can define a surface perpendicular to the lines of the magnetic field if you want to, but that's not necessary for the statement in question - it's true for any closed surface, no matter how it is oriented.
And no - the magnetic field is not zero, nor is the flux (this was stated in an earlier post - please read them all). It's the net flux, i.e. the sum of all the flux lines across the surface, that is zero. It just means that there is much field "flowing" out of the surface as there is field "flowing" into the surface. Again, it has to do with the closed loops: every one that exits must also reenter.
Ok, I understand now. And what happens in the Faraday's cage? Are just the sum of all the flux lines zero?
Well, that's kind of a funny question, since a Faraday cage relies on the presence of electric charges on the surface, so there will be flux line originating on the surface itself. I guess the correct thing to say, since there are no flux lines in the space inside the surface, is that the flux lines from any external field are exactly canceled by the flux lines from the rearranged charges on the cage, so you could conclude that the flux is zero everywhere on the surface, not just summed up.
That's my immediate response, anyway. Maybe someone else will disagree ... :confused:
And can I ask you another question? How is possible that the field of the permanent magnet is changed (delta B)? Here is the http://hyperphysics.phy-astr.gsu.edu/hbase/electric/farlaw.html#c2"
The field of the permanent magnet is not being changed. The field (and thus flux) within the conducting loop changes as the magnet is moved.
But I think, if I get close permanent magnet (depends on the material), the magnetic domains inside the loop will align, so it will become also permanent magnet. So when I'll return the magnet back, the domains will not align like on the start, right?
No. Treat the conducting loop as being made from a non-magnetic material, such as copper wire.
So, when I put back the magnet, the magnetic domains of the conducting loop will realign, right?
Physicsissuef said:
So, when I put back the magnet, the magnetic field of the conducting loop will realign, right?
The only magnetic field contribution from the conducting loop is due to the current flowing through it.
Yes, but there are 3 kinds of fields, in this case. B induced, the magnetic field induced due to flowing current, B, the field of the permanent magnet, and delta B, which is actually I think the field inside the coil, but from the spin and orbital momentum of the electrons. So, I think that when I approach permanent magnet, so it will align the domains (temporary), because there is non-magnetic material. But when I get back the permanent magnet, the domains will realign in their first condition. What do you think?
I think you're confusing issues when you speak of domains realigning in this case. The induced electric current is what creates a B field to compensate for the changing flux. There's no need to speak of domains, nor of additional fields - not explicitly, at least. You can just use Faraday's Law to calculate the induced current, and you don't have to think about the induced B field at all.
I think, I am right in this case. How does the delta B field changes than, by your opinion?
Btw- Here says that B is external magnetic field, thus delta B is change of the external magnetic field. What is http://hyperphysics.phy-astr.gsu.edu/hbase/electric/imgele/fday.gif"
No, there are only two sources of magnetic field in this situation. The field from the magnet and the induced field from the current. "Delta B" is an attempt to describe how the magnetic field is changing due to the movement of the magnet. For example: When you move the north pole towards the coil, delta B points towards the coil (since the field in the coil is increasing).
I think you're mistaken. :wink:
So delta B in practical way, doesn't exists, right?
  • · Replies 24 ·
  • · Replies 26 ·
  • · Replies 25 ·
