Thread Closed
[SOLVED] Problem finding angular velocity... !!
Share Thread Thread Tools
Jan17-08, 01:31 PM   #1
The 9.65 lb uniform disk is pin supported at its center and is acted upon by a constant force of P = 1.45 lb as shown. The system starts from rest. Radius of disk is .470 ft
The force P is going straight down from the disk and would spin the disk in a clockwise direction. The force P is at the end of a string.. making the disk spin.
Determine the angular velocity after 4.45 seconds. (rad/s, +CCW)
2. Relevant equations
I know this problem involves a constant accel equation. I believe the right one is angvelfinal = angvelinitial + a*t
3. The attempt at a solution
The issue i have is that i can't figure out how to relate the force acting on the disk to turn it into acceleration. I have tried setting "Force*Radius=(.5*Mass*radius^2)angaccel" and solving for angaccel and then multiplying it by the time in order to get my angvel but i am having no luck. Any help i appreciated.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jan17-08, 02:22 PM   #2
any other info i need to give guys?? i have been on this question for two days lol. I can finish it i just can't figure out how i get from a force in lbs pulling down on a string turning a disc... to the acceleration of the disc. Ive looked through formulas and have had no luck anywhere.
Jan17-08, 05:53 PM   #3
thanks guys, i figured it out. I was doing it right but somehow my numbers were off somewhere.
Thread Closed
Thread Tools
Similar Threads for: [SOLVED] Problem finding angular velocity... !!
Thread Forum Replies
Torque graph; finding angular velocity Introductory Physics Homework 5
[SOLVED] another angular velocity problem Engineering, Comp Sci, & Technology Homework 0
[SOLVED] Unstretched Spring and Angular Velocity Problem Introductory Physics Homework 7
Finding angular velocity Introductory Physics Homework 2
Cylinder about side, finding angular velocity.... Introductory Physics Homework 3
