Gauss's and Coulomb's law forms and gravitational field
The discussion explores the relationships between Gauss's law, Coulomb's law, and gravitational fields, examining potential similarities in their mathematical formulations and the possibility of gravitational fields inducing other fields. It encompasses theoretical considerations, mathematical reasoning, and speculative ideas regarding gravitoelectromagnetism (GEM).
  • Some participants discuss the derivation of Coulomb's law from Gauss's law, suggesting that similar derivations could apply to gravitational fields with appropriate constants.
  • One participant proposes that if electric fields can induce magnetic fields, gravitational fields might also induce another field, drawing parallels to Maxwell's equations.
  • Another participant mentions the concept of gravitoelectromagnetism (GEM) and its resemblance to Maxwell's equations, noting that it arises in certain solutions to general relativity.
  • Some participants highlight the inverse-square relationship inherent in both electric and gravitational fields, attributing it to the distribution of flux lines over increasing surface areas.
  • There is a discussion about the non-linear nature of gravity and the challenges in establishing experimental relationships between gravitational and electromagnetic forces.
Participants express multiple competing views regarding the similarities between electric and gravitational fields, the nature of gravitoelectromagnetism, and the implications of these theories. The discussion remains unresolved with no consensus on the validity of the proposed relationships.
Some claims rely on specific assumptions about the nature of fields and their interactions, and the discussion includes references to unresolved mathematical steps and the limitations of current theories in fully describing gravitational interactions.
This discussion may be of interest to those studying theoretical physics, particularly in the fields of electromagnetism, general relativity, and gravitational theories.
user01
Consider int(E.dA)=q/e, Gauss law relating the electric field to the charge enclosed.
One can also derive (using the more mathematical version of Gauss' law - involving the double integral) this same formuala for a graviational field. Here the permitivitty constant would be replaced by another arbitrary constant.
Does anybody know where one can obtain the derivation to Coulombs law,
F = 1/4pi E qq/r^2, more specifically relating to the 'electrostatic constant' k = 1/4pi E?
Considering that the electric and gravitational fields are similar in terms of flux and field lines, wouldn't there be similar equations for gravity as maxwell's laws describe EM. Is it possible for the gravitational field to induce another field?
From Gauss's law, whose differential form is [tex]\nabla \cdot \vec{E} = \frac{\rho}{\epsilon_0}[/tex], one can derive Coulomb's law using [tex]\rho = q\delta^3(\vec{r})[/tex] (ie a point particle).
Thanks for the link to wiki (K.J H), that's quite useful.
I was thinking more along the lines, that if E induces B, and vice versa, then it might be possible that the gravitational field induces another field also.
In maxwells four equations (simplified), we have gauss, int(E.dA)=q/e and int(B.dA)=0 as the first two (not using the differential forms to keep it simple as one can).
Then one can derive gauss in the same way for the gravitational int(G.dA)=m/w, where G is the graviational field, m is the mass instead of charge, and w is a constant similar to the permitivitty. (derived using 'linking number' double integral)
Also the strong field can be written as int(S.dA)=0 since there is always to nucleon constituents present whenever the strong force is present (net flux=0).
Then obviously the question arises if the two fields (S and G) can induce one another?
yes. Gauss's law applies to any field that is an inverse-square field. it arises naturally from the inverse-square relationship.
well, it's not an arbitrary constant (given our units of measurement). it's related to G just like in Coulomb's law it's related to "k".
consider the density of those flux or field lines (called "flux density") for the same charge (electric) or mass (gravitational) distributed on the surface areas of increasing concentric spheres. if you double the radius of the sphere, the surface area increases by a factor of 4, and the same number of flux lines is now distributed over an area 4 times as much. so now the flux density is 1/4 as large. that is fundamentally where the inverse-square relationship comes from in 3-dimensional space.
as someone else pointed out, it's called gravitoelectromagnetism (GEM) and has equations that look like maxwell's equations. they really come from a limiting case (reasonably flat spacetime) of Einstein's GR equation and i don't know enough about GR to derive it. but if you compare to E&M, think about it this way: in both E&M and GEM, you have this inverse-square relationship when things are static. in EM, you can derive the magnetic effect directly from electrostatics but also keeping the effects of special relativity in mind (i.e. magnetic forces are really just relativistic manifestations of electrostatic forces). then take the "gravitostatic" force action (Newton's law), apply the same song-and-dance (of how electrostatic becomes electromagnetic) to the gravitostatic field, and you get something that resembles GEM, that is an inverse-square field with gravito-magnetic effects and a speed of propagation of c. for some reason that i do not understand, there is a factor of 2 tossed in because gravity is a "spin-2" action not a spin-1 action as EM. I've asked the physicists here for a little bit of explanation long ago but never understood any reply.
this thread should maybe go into the SR/GR forum, because that's what it's about. maybe some admin would like to move it.
the relationship between gravito magnetism and maxwell's equations is pretty simple, you could effectively postulate a lorentz invariant form of Newtonian gravity by just making the analogue to the electromagnetic field and defining an additional vector field which would play the same role as the magnetic field.
the reason why such equations beak down is pretty simple. from special relativity energy is related to mass which in turn creates a gravitational field, however this gravitational field also contains energy which is related to mass and thus creates a bigger gravitational field, etc. etc.
so the full theory of gravity must be non-linear. Einstein developed this as GR, however in the case of a weak field, where space time is almost minkowskian, then that maxwell-analogue becomes accurate again and GR actually reduces back down to it.
The latter of maxwell's equations, which describe changes in flux that produce certain fields really unify E & B fields. Also, simple experiments on a macro level prove this.
I wasn't aware that gravity can induce another field, or vice versa. Where the strong field is unity, EM is on the order of a few hundreth in comparitive strength, but gravity is on the order of 10^-39. How can one prove any relationship between these other forces (as postualted in GEM) experimentally?
  • · Replies 83 ·
  • · Replies 29 ·
  • · Replies 30 ·
