Two Engines, One Control System: Impossible or Inevitable?
The discussion revolves around the potential causes of simultaneous engine failure in a Boeing 777 during descent, focusing on the roles of engine icing, fuel management issues, and control systems. Participants explore various hypotheses related to technical failures, environmental conditions, and operational protocols.
  • Some participants suggest that engine icing could have caused both engines to slow down, leading to generator failure.
  • Others argue that the likelihood of icing affecting the generators is low due to the thermal properties of the engines and their design.
  • There is speculation about whether the issue could be a type problem or a rare set of circumstances, with a consensus that aircraft must exceed million-to-one failure odds.
  • Concerns are raised about the effectiveness of bleed air in larger engines like the 777 and A380, particularly under icing conditions.
  • Some participants propose that fuel starvation might explain the simultaneous engine failure, questioning the reliability of fuel gauges and monitoring systems.
  • References to past incidents involving the 777 and Chinook helicopters are made to draw parallels and highlight potential systemic issues.
  • One participant mentions that ice could form in the bottom of fuel tanks, potentially leading to engine starvation without triggering warnings.
  • There is a discussion about the FADEC systems, with some expressing skepticism about the simultaneous failure of both systems.
  • Participants share anecdotal experiences and insights from industry professionals regarding the reliability of aircraft systems and the implications of technical failures.
Participants express multiple competing views regarding the causes of the engine failure, with no consensus reached on the most plausible explanation. The discussion remains unresolved, with various hypotheses being explored.
Participants acknowledge limitations in available data and the complexity of the technical issues involved, including the dependence on specific operational conditions and definitions of failure modes.
Aviation enthusiasts, aerospace engineers, and professionals in the field of aircraft safety and maintenance may find this discussion relevant.
The suggestions on the aviation forums are that engine icing could have slowed both engines to the point that the generators dropped out.
Would this be a type problem or general or may be a million to one set of circumstances?
I think blade icing is a problem in large diameter engines like the 777 and A380
as the engine gets bigger the bleed air to heat the blades is less effective.
The suggestion is that the engines were icing but were running at low power - on descent so it didn't matter - when the pilot turned up the power they both slowed quickly.
I suppose you can't carry enough battery power to run the controls without the generators but it is worrying on something like the 787 where the surfaces are powered by electric actuators.
The other suggestion is that it ran out of fuel, it shouldn't have and would have given a warning - unless the plane had been improperly filled and the gauges/fuel monitors had failed.
No way. Generators on large engines are driven by large transmissions called CSDs (constant speed drives). I have a very hard time believing that there would be nacelle icing that was so bad to ice up a generator to the point of not working. The thermal soakback from the engine alone should be enough to keep it happy, not to mention the relatively hot cooling oil circulating through it. I would need a lot more data to convince me of that one.
Icing, in general, is a tough one to accept. When we certify an engine, we go down to Eglin AFB and put it in their icing facility. The engine has to perform under severe icing conditions. The same is for the big boys. Again, there would have to be an normous amount of icing to do what is being described.
The idea that both FADEC systems went bad is pretty remote.
The fuel idea is the simplest and most direct one that is easiest to accept at this point.
Whatever the problem ends up being, it is both. Planes are required to have reliability that exceeds million-to-one failure odds.
Yes, having seen the conditions they are tested under in Canada - it's hard to believe a foggy morning in London could kill both engines.
Is this the same Boeing that does FADEC on the RAF Chinooks?
There was a suggestion that ice forming in the bottom of the tanks is a problem on the 777, I don't know if this could happen in such a way as to make the fuel management system think it was OK but still starve the engines.
I wish some organization besides Wikipedia would post the details, but - http://en.wikipedia.org/wiki/British_Airways_Flight_38
Does icing of the engines or fuel system seem credible/plausible based on the plane and location? I imagine that similar aircraft were flying similar or more onerous conditions. Beijing to London is a polar round IIRC, and I've flown similarly northern routes from Tokyo/Osaka to NY(EWR/JFK)/SFO. The route and the conditions are not that unique, and the 777 is a more advanced aircraft.
Some more information.
http://aviation-safety.net/database/record.php?id=20080117-0
http://www.aaib.dft.gov.uk/latest_news/accident__heathrow_17_january_2008___initial_report.cfm
Interestingly, there was a problem with the 777 in Australia.
http://www.airlinesafety.com/faq/777DataFailure.htm
On August 1, 2005, a Boeing 777-200, which had departed from Perth, received an EICAS (Engine Indication and Crew Alerting System) warning of low airspeed, as the plane was climbing through FL (flight level) 380. Simultaneously, the aircraft’s slip/skid indication moved full right, on the PFD (Primary Flight Display). The PFD speed tape also displayed contradictory information: that the plane was approaching both the high speed limit and the low speed (stall) limit. The aircraft, still connected to the autopilot, pitched up and climbed to approximately FL410 as the airspeed decreased from 270 kts to 158 kts. The stall warning devices also activated.
I wonder if this failure had any commonality with the BA038 problem.
Hmmm. That's a curious question. To answer, the FADEC is produced by the engine manufacturer, not the airframer. So th answer would be no. It would be developed and produced by GE whereas the Chinook (genuflect when you say that) uses Honeywell-Lycoming T-55's. Has there been any issues in the UK with their aircraft? I try to keep an ear to the ground when it comes to Chinook issues and I haven't heard anything.
Is that on the inside of the tanks? Anything is possible, that's for sure.
There was a crash about 10years ago of an RAF Chinook. The craft had been updated with new FADEC, the crash was blamed on pilot error (many felt unfairly) and it was felt the technical problems were covered up - apparently the entire model was grounded and still haven't been returned to service.
The helicopter was on a secret mission carrying inteligence officers/agents and special forces from Northern Ireland so there was a general air of cover-up.
http://en.wikipedia.org/wiki/1994_Scotland_RAF_Chinook_crash
I remember that crash. I jut read a blurb in my aerospace testing magazine that the MoD has just allowed an upgrade program to go to the HC3. I had never heard anything about the FADEC problems though, just the overall control systems. It's strange because there are so many operational Chinooks around the world. I wonder if there is a difference in the types of controls. Thanks for the link.
I work with a man (one of our consultants) who was involved in the development of the 777 landing gear. He believes they simply ran out of fuel on final approach. The plane was coming from China, so it's as plausible as any specualations at this point. The reason we wouldn't hear about that right away is it that would be an embarassing admission. It would certainly explain sudden engine failure in BOTH engines at the same time.
Also, he said the landing gear failed correctly. From the pictures of the landing gear that separated you can see where one of the enormous titanium supports sheared completely. Amazing!
Sounds like a loss of fuel pressure due to ice cover. Someone removed an ice shield or heat shield and never placed it back in.
  • · Replies 39 ·
