Finding Probabilities of Spin 1/2 System Measurement
The discussion revolves around a quantum mechanics problem involving a system of two spin 1/2 particles. The Hamiltonian is given as H=w_1 S_1z + w_2 S_2z, and the initial state of the system is expressed as | \psi (0) > = \frac{1}{\sqrt(2)}[|+ -> + |-+>]. The primary question is about measuring the total spin squared, S^2 = (S1+S2)^2, and determining the possible outcomes and their probabilities.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to find the Hamiltonian to understand the system's evolution and the eigenvalues of energy. There are attempts to apply the time evolution operator to the initial state and to express the state in terms of the Hamiltonian basis. Questions arise regarding the number of eigenvalues and the application of the S^2 operator.
The discussion is ongoing, with participants sharing insights on how to approach the problem. Some have suggested decomposing the initial state and applying the time evolution operator, while others are questioning the application of the S^2 operator and its implications. There is recognition of the complexity involved in calculating probabilities and the need to project the evolved state onto specific spin states.
Participants note that the total spin of a two spin 1/2 system can yield values of either 1 or 0, which affects the expected outcomes for S^2. There is mention of additional parts to the problem that involve finding relationships between parameters to simplify the probabilities.
Erythro73
[SOLVED] Addition of Spin 1/2
A system is composed of two spin 1/2. The system's hamiltonian is [itex]H=w_1 S_1z + w_2 S_2z[/itex]. The initial state of the system is, at t=0,
[itex]| \psi (0) > = \frac{1}{\sqrt(2)}[|+ -> + |-+>][/itex].
a) At time t, we measure [itex]S^2 = (S1+S2)^2[/itex] What results can we find and with what probabilities?
[itex]H\psi = E\psi[/itex]
So, I think the first step is to find the Hamiltonian of my system to know how the system will evolve, as we need the eigenvalues of the energy in the exponential.
So I thought of doing
[itex](w_1 S_1z + w_2 S_2z)|\psi (0) > = E|\psi(0)>[/itex]. But, here, I'm not so sure of what to do. I mean, [itex]S_1z[/itex] is a two-D operator while psi(0) is a 4x1 matrice (0 1 1 0) (placed vertically). This matrix product doesn't seem correct to my senses.
hum... instead, using [itex]S_1z|+ - > = \frac{\hbar}{2} |+->[/itex] and so on, I have the eigenvalue [itex]E=\frac{\hbar}{2}(w_1 - w_2).[/itex]. The problem is... am I not supposed to have more than one eigenvalue of energies? Because the eigenvalue equation [itex]H\psi = E\psi[/itex] then gives me
[itex]\frac{\hbar}{2\sqrt 2}(w1-w2)[|+-> + |-+>]=E\psi[/itex].
I seem to have advanced to the solution. But I don't know where to go from there :S?
What is the time evolution of the state
If the hamiltonian is given by :
[itex]H=w_1 S_{1z} + w_2 S_{2z}[/itex] ?
(I assume you meant this, so i fixed your latex code)
So first find [tex]\psi (t)[/tex], by applying the time evolution operator to [tex]\psi (0)[/tex].
then you apply the operator [itex]S^2 = (S1+S2)^2[/itex] and find the possible outcomes and probs.
So you have [tex]\psi (0)[/tex], decompose it, a hint;)
also
[itex]S^2 = (S_1+S_2)^2[/itex] You manipulate a bit.
Hi malawi, thanks for your help,
Yes, that is what I was trying to do (I need energy eigenvalues in order to apply the time evolution operator). The problem is actually finding energy eigenvalues...
Using your idea of decomposing [itex]\psi(0)[/itex], maybe it would be a nice idea to express [itex]\Psi(0)[/itex] in the hamiltonian basis and then actually find the eigenvalues of [itex][\psi(0)]_E[/itex].
Then, I would have energy eigenvalues... right...?
Oki, if I start, then you can fill in the rest.. (we shall now find the evolved state [tex]\psi (t)[/tex])
Time-ev op: [tex]U(t,0) = \exp (-iHt/\hbar )[/tex]
initial state: [itex]| \psi (0) > = \frac{1}{\sqrt(2)}|+ -> + \frac{1}{\sqrt(2)}|-+>[/itex]
So the first ket on the RHS: evolves according to:
[tex]U(t,0) |+ -> = \exp (-i(w_1 S_{1z} + w_2 S_{2z})t/\hbar )|+ -> =[/tex]
[tex]\exp (-i(w_1 \hbar / 2 - w_2 \hbar /2)t/\hbar )|+ -> =[/tex] ...
I hope you got the idea, now continue to get the final [tex]\psi (t)[/tex].
Time-ev op: [tex]U(t,0) = \exp (-iH/\hbar )[/tex]
[tex]U(t,0) |+ -> = \exp (-i(w_1 S_{1z} + w_2 S_{2z})/\hbar )|+ -> =[/tex]
[tex]\exp (-i(w_1 \hbar / 2 - w_2 \hbar /2)/\hbar )|+ -> =[/tex] ...
Got it! I forgot that subtility of "decomposing" the [itex]\psi[/itex] function. I forgot that the function was a linear combination of the two independent states. I feel somehow ashamed.
So
[itex] \psi(t)>=\frac{1}{\sqrt 2}|+ -> \exp(-\frac{-i}{2}(w_1 - w_2)t) + \frac{1}{\sqrt 2} |- +>\exp(\frac{-i}{2}(-w_1 +w_2)t))[/itex]
Now, I just have to apply [itex]S^2[/itex] to my [itex]\psi(t)[/itex] and see what eigenvalues I can have...
[itex]S^2| \psi(t)> \frac{1}{\sqrt 2} ( \exp(\frac{-i}{2}(w_1 - w_2)t) \hbar ^2 [|+-> +[-+> ] + \exp(\frac{-i}{2}(w_2 - w_1)t) \hbar ^2 [|+-> +[-+> ])...[/itex]
Which eventually leads to
[itex]S^2| \psi (t) > = 2\hbar ^2 | \psi (t)>[/itex]
... Which makes me wonder why there's only one eigenvalue...? :S I must be forgetting something somewhere...
THanks for your help.
It is not THAT straightforward to operate with [tex]S^2[/tex]
Did you write [tex]S^2 = (S_1 + S_2)^2 = S_1^2+S_2^2 + 2S_{1z}\cdot S_{2z} + ...[/tex] ?
Well, in my course, the teacher developped the expression you wrote and concluded that[itex] S^2|++>=\frac{3}{4}\hbar^2|++> + \frac{3}{4}\hbar^2|++> + \frac{1}{2}\hbar^2 |++> +0 = 2\hbar^2 |++>[/itex]
and by similar development :
[itex]S^2|-->=2\hbar^2|-->[/itex]
[itex]S^2|+->=\hbar^2[|+->+|-+>][/itex]
[itex]S^2|-+>=\hbar^2[|+->+|-+>][/itex]
... Did I apply the operator too naively?
I used these identities to calculate the effet of S^2 on my function... Was it wrong :S ?
if you write [tex]\psi (t) = A(t)|+-> + B(t)|-+>[/tex]
where [tex]A(t) = \exp (-i(w_1 \hbar / 2 - w_2 \hbar /2)t/\hbar )[/tex]
and B(t) is the other exp..
Then see what you get.
is there a part b) and c) on this question also?
The total spin of a two spin ½ system is either 1 or 0, so S^2 should give you the value 2 or 0, but the problem here is to find out their probabilties as a function of time.
So i think you should take these functions:
[tex]\frac{1}{\sqrt(2)}[|+ -> + |-+>][/tex] (the spin S = 1, M_s = 0 state)
and [tex]\frac{1}{\sqrt(2)}[|+ -> - |-+>][/tex] (the spin S = 0, M_s = 0 state)
and projectet onto [tex]\psi (t)[/tex]
But I must admit that this was a kinda tricky problem :S
So, knowing that, we can write that
[itex]S^2|\psi(t)>=A(t) \hbar^2 [|+->+|-+>] + B(t) \hbar^2[|+->+|-+>][/itex].
That means that it is equal to (if I regroup the terms)
[itex](A(t)\hbar^2|+->+B(t)\hbar^2|-+>) + (A(t)\hbar^2|-+> + B(t)\hbar^2|+->)[/itex]
[itex]=(\hbar^2 \psi(t) ) + (\hbar^2 \phi(t))[/itex]
Where [itex]\phi(t)[/itex] represend the last term.
Yes, there's a part b) which is to find out the relation between w1 and w2 so that the probabilities are independent of time. Which, I expect, should be fairly easy once part a) is done ;).
So you are saying that I should try, instead of doing what I wrote in my last message, to write psi(t) in function of the two functions you wrote. OK, but I do not have any minus coming from the relations I used... :S.
Ok, I got it.
So, to do a small résumé, I
1) Had to find the possible energies to use the time evolution operator. For this, I applied H on |+-> and |-+>.
2) Then, I was able to write my function psi(t)
3) As this function evolve in time, it's not a surprise it would be a linear combination of the two possibles values of spin (1 0) (0 0). So I can write my psi(t) function in a linear combination of (1 0) and (0 0).
4) Happily enough, this is quite simple. I wrote |+-> and |-+> in function of |0 0> and |1 0> and put it in psi(t).
5) Then, I can find quite easily the possible values of S^2, especially if I use some trig. identities involving cos and sin in function of complex exponential.
6) The probabilities are then proportional to cos^2 and sin^2 and the values are 2hbar^2 and 0.
Thank you very much, malawi_glenn. Your help was very much appreciated! :)
P.S. I don't know how to put [Solved] beside my thread's title. But it is pretty much solved.
Erythro73 said:
Ok, I got it.
That looks ok and reasonable :) Good work!
  • · Replies 21 ·
