Fuel Cell Electrons: Anion Movement, Protons, and DC
The discussion revolves around the mechanisms of electron and proton movement in fuel cells, particularly in proton-exchange membrane fuel cells. Participants explore the reasons behind the movement of electrons from the anode to the cathode and the role of protons in this process, addressing both theoretical and conceptual aspects.
  • One participant describes fuel cells as generating power by influencing electrons to move through an ion-conducting material, questioning the necessity of their journey to the cathode.
  • Another participant explains that in a proton-exchange membrane fuel cell, protons can pass through the membrane while electrons must travel through an external circuit to reunite with protons.
  • A participant raises a question about the lack of attraction for protons to move across the membrane, suggesting entropy as a possible factor.
  • Another participant clarifies that the movement of protons is due to diffusion, emphasizing the role of free protons in the membrane.
  • Concerns are expressed about the electrons' need to travel a distance to reach protons, especially when they are initially closer to the anode.
  • One participant notes that the membrane's thickness is minimal and confirms that electrons recombine with protons on the other side.
  • Another participant points out that the movement of electrons in a conductor is more about the collective behavior of the electron sea rather than individual electrons traveling long distances.
Participants express varying levels of understanding regarding the movement of electrons and protons, with some agreeing on the diffusion process while others question the necessity and mechanics of the electron's journey. The discussion remains unresolved with multiple competing views on the underlying processes.
There are limitations in the discussion regarding the assumptions about the forces acting on protons and electrons, as well as the specifics of the distances involved in their movement. The role of entropy and diffusion in the context of fuel cells is also not fully explored.
Nim
From what I understand about fuel cells, they generate power by influencing electrons to move themselves around an ion-conducting material to get to the other side. While the electrons make there way from one side to the other, they supply DC in the middle of there journey. But I am not quite sure why they are going to the other side.
Exactly how far does the electron actually stray away from the protons on the other side to get to them (that's what they are going for right)? Why do they leave the positive side (anode) to get to the negative side (cathode)? I know that they are attracted to protons, but the protons are farther away from them than the anode is and they are on the cathode side which should be repeling them.
In a proton-exchange membrane fuel cell, protons go right through the membrane from one side to the other. The electrons cannot pass the membrane (it's semipermeable), and, in order to reunite with the protons, must go around the electrical circuit.
- Warren
Chroot,
There doesn't seem to be anything attracting the protons across the membrane to the cathode. Is it just entropy?
It's just a diffusion situation. There are no hydrogen ions on one side of the membrane, but many on the other. The hydrogen ions thus diffuse across the (quite permeable) membrane.
Proton-exchange membrane fuel cells are made using an organic membrane, like polyfluorosulfonic acid. The hyrogen ions on the acid groups are essentially free. Just like the free electrons in an electrical conductor allow electrons to move from one place to another, the free protons in the membrane allows protons to move easily from one place to another.
Here's a good page:
http://www.dodfuelcell.com/proton.html
- Warren
That's the part I understand. The part that I don't understand is why they would bother going around the membrane just to reach the protons when there is an anode right there infront of them. Plus the protons are on the negative side. I don't know how far they have to travel to get to the other side, but they are supposed to supply DC current. It's hard to imagine an electron going far out of its way to get to a proton, especially when it has to move farther away before it can start moving closer.
What happens to all of the excess electrons then? Are not all of the electrons recombining with the hydrogen ions on the other side?
The membrane is about as thick as saran wrap. The electrons do indeed recombine with the protons on the other side.
- Warren
Yeah, I know that.
Nim,
I'm not sure what you don't understand. The protons go through the membrane simply because of diffusion; the electrons cannot follow. They go through the circuit to come back and reunite with the protons. That's the whole story.
- Warren
Nim said: "It's hard to imagine an electron going far out of its way to get to a proton, especially when it has to move farther away before it can start moving closer."
The same thing happens when you discharge a capacitor.
Fields in conductors are complicated, but the results they give are easy. If the net charge in a conductor is zero, the charge density at any point is zero. The electrons do whatever's needed to make that happen.
Edit: But the idea that a single electron goes all the way around to the other side is misleading. The whole sea of electrons in the conductor moves a tiny bit in that direction, and that's enough to neutralize a proton in the cathode.
