Soldering tap points onto a coil
by Jdo300
Tags: coil, points, soldering
Jdo300
Jdo300 is offline
#1
Jan20-08, 11:04 PM
P: 545
Hello All,
I'm making a long coil for some experiments and I want to put some tap points onto the coil without actually cutting the wire. I was wondering if anyone knows of a simple way to do it?
The coil is made out of insulated 22 gauge wire (regular not mag wire) wrapped on a core that is 1.5 inches in diameter and about 10 inches long. Currently, I have been using my soldering iron to melt the insulation and then solder short pieces of wire to it but it's messy and I'm sure that the fumes from the insulation are not all that good for you (I do have a fan near by). How would you all do this?
Thanks,
Jason O
Phys.Org News Partner Engineering news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
WSU innovation improves drowsy driver detection
Faster computation of electromagnetic interference on an electronic circuit board
waht
waht is offline
#2
Jan21-08, 09:20 AM
P: 1,636
Try to use a sandpaper to scrape off the insulation.
berkeman
berkeman is offline
#3
Jan21-08, 11:32 AM
Mentor
berkeman's Avatar
P: 39,708
Quote Quote by waht View Post
Another common technique is to use an Xacto knife to scrape off a bit of the insulation. You can also use the knife to make two partial-circumferential cuts on the insulation a couple mm apart, then slit along the wire between those two cuts and peel back to expose some copper to solder to.
Jdo300
Jdo300 is offline
#4
Jan21-08, 05:29 PM
P: 545
Ahhh makes sense. Thank you both for the suggestions!
- Jason O
Register to reply
Related Discussions
A coil with turns given magnetic field, time find the emf induced in the coil Introductory Physics Homework 4
What is the theoretical limit to coil inductance over coil resistance? Electrical Engineering 15
Soldering Wire?? Electrical Engineering 2
Topology (Boundary points, Interior Points, Closure, etc...) Calculus & Beyond Homework 13
boiling points, melting points and absorbed radiation Q's Introductory Physics Homework 0
