Thread Closed
converges absolutely, conditionally, or diverges
Share Thread Thread Tools
Jan21-08, 12:22 AM   #1
does this series converge absolutely, conditionally, or diverge?
what test to use for this problem: http://img525.imageshack.us/img525/2296/35297847wb1.png
2. Relevant equations
3. The attempt at a solution
not sure where to start. also n!^2 is that a p-series?
thankyou.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Jan21-08, 12:25 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Argue, that for large enough n, (n+2)!/(n!)^2<1
Jan21-08, 12:49 AM   #3
is this a series that I could use the limit comparison test, so compare that to 1? then compare this to the original problem?
also, looks like a p-series to me.
Thanks so far.
Jan21-08, 01:21 AM   #4
Recognitions:
Quote by rcmango View Post
That's pretty definitely not a p-series. Such a series would simply use n raised to a power, rather than n!
Have you had the Ratio Test yet? That's really the most effective technique on a general term of this sort. Also, if you succeed in showing that this series converges absolutely (since it contains no alternating term), you'll be done. (Ah, but perhaps I've said too much...)
(Hmm, if you have only gotten to the comparison tests, you'd need to use a ratio bigger than the general term that you know will give a convergent series. You could make the denominator smaller by looking at the series for just (n+2)!/[ (3^n) · n! ] , simplify that , and show that this series converges, so yours does, too.)
Jan21-08, 02:40 AM   #5
Recognitions:
Note that:
[tex]\frac{(n+2)!}{(n!)^{2}}=\frac{n!}{n!}\frac{(n+1)(n+2)}{n!}=\frac{(1+\fr ac{1}{n})(1+\frac{2}{n})}{(n-1)!}[/tex]
What does this tell you?
Jan22-08, 03:17 AM   #6
Thanks for the help. I may need help simplifying the factorial in the denominator though.
i believe that now looks like 1/ (n -1)! ?
where 1/n = 0 in and 2/n = 0. so 1/ the factorial is less than one, correct?
what happened to the 3n?
thankyou.
Jan22-08, 03:26 AM   #7
Recognitions:
What happened to it?
It is still there!
What you have shown is that given n>3, the terms in the series is less than 1/3^n.
What does that tell you about the series?
Thread Closed
Thread Tools
Similar Threads for: converges absolutely, conditionally, or diverges
Thread Forum Replies
converge absolutely or conditionally, or diverge? Calculus & Beyond Homework 7
series converges or diverges? Calculus & Beyond Homework 5
converge absolutely or conditionally, or diverges? Calculus & Beyond Homework 6
converge, absolutely or conditionally? Calculus & Beyond Homework 4
Show the integral diverges Introductory Physics Homework 8
