Potential Inside a Hollow Conduction Sphere
The potential inside a hollow conducting sphere with a uniform surface charge density σ is given by the formula V = aσ / ε₀, where a is the radius of the sphere and ε₀ is the permittivity of free space. The electric field inside the sphere is zero, leading to a constant potential throughout its interior. To derive this, one can integrate the contributions from infinitesimal surface charges or apply the well-known theorem of hollow spheres. The potential at the surface is equivalent to the potential at any point inside the sphere.
  • Understanding of electric potential and its mathematical representation
  • Familiarity with the concept of surface charge density (σ)
  • Knowledge of integration techniques in calculus
  • Basic principles of electrostatics, particularly regarding hollow conductors
  • Study the derivation of electric potential from point charges using the formula φ(𝑥) = (1/4πε₀) * (q/|𝑥 - 𝑥₀|)
  • Explore the theorem of hollow spheres and its applications in electrostatics and gravitation
  • Learn about the implications of electric field strength being zero inside conductors
  • Investigate the concept of potential energy in electrostatics and its relation to charge movement
Students of physics, electrical engineers, and anyone studying electrostatics or seeking to understand the behavior of electric fields and potentials in conductive materials.
Cheetox
Here is a question I have been pondering on for a while and got rather stuck, could anyone help out?
'A charge is diestributed uniformley with density [tex]\sigma[/tex] over the surface of a hollow conducting sphere of radius a. Show by direct integration that the potential at any point inside it is a[tex]\sigma[/tex] / [tex]\epsilon[/tex]0 and that this is the potential of the sphere itself'
plus could anyone give me a really good definition (mathmatcially and in words) for potential, I havn't really grasped it,
many thanks
The electric potential is a quantity that represents potential energy per unit charge. It is measured in volts, which are the same as joules per coulomb.
So basically, if the potential difference between points A and B is V, then a charge of magnitude Q, resting at A, has a potential energy of QV to travel from A to B.
Mathematically, the potential of a point charge at [itex]\vec x_0[/itex] is given by
[tex]\phi(\vec x) = \frac{1}{4 \pi \epsilon_0} \, \frac{q}{|\vec x - \vec x_0|} + C[/tex]
where C is an arbitrary constant, usually set to zero.
It's a well-known theorem of hollow spheres that the electric field strength on a charge anywhere inside the sphere is 0. Integrating 0 gives a constant, and that is why the potential is constant.
Ie the potential is whatever you set it to.
Teacher probably wants you to assume potential at infinity to be 0, so that the potential at the surface works out to:
V = - 1/4πε Q/r (relative to infinity)
Q is the total charge, ie
Q = σ * surface area = σ 4πr^2
So the potential at any point inside, is the same as the potential at the surface ie
V = - σr/ε
If you don't want to use the theorem of hollow spheres (applies to gravity to), you have to integrate Ben's formula over the entire surface, ie cut the sphere up in infinitesimal charges dq.
And the integral is not trivial.
  • · Replies 29 ·
