If f is continuous on [a,b], then f is bounded on [a,b].
The discussion revolves around a theorem in real analysis concerning the properties of continuous functions on a closed interval [a,b]. The original poster is attempting to prove that if a function f is continuous on [a,b], then the set S, defined by certain conditions related to boundedness on subintervals, is equal to [a,b].
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the necessity of demonstrating the existence of elements in S beyond just a. There are suggestions to utilize properties of continuous functions, such as the mapping of compact sets and the implications of the Heine-Borel theorem. The original poster expresses confusion about how to proceed with the proof and questions the role of continuity in establishing boundedness.
Several participants have provided insights and suggestions for approaching the proof, including references to the intermediate value theorem and the importance of continuity in achieving maximum and minimum values. However, there is no explicit consensus on the next steps, and the discussion remains open-ended with various lines of reasoning being explored.
The original poster has indicated a desire for clarity in explanations and has expressed uncertainty about the implications of continuity on boundedness, which may influence the direction of the discussion.
Esran
Dear friends,
I just joined the forums, and I'm looking forward to being a part of this online community. This semester, I signed up for Analysis II. I'm a math major, so I should be able to understand pretty much everything you say (hopefully). However, I'd really appreciate it if you try not to be too arcane in your explanations.
So, here's the theorem I'm stuck on.
Question: Prove...
Suppose f is continuous on [a,b] and S is the set such that x is in S if and only if x is in [a,b] and, (1) x = a or (2) f is bounded on the subinterval [a,x]. Then S is [a,b].
This is what I have so far.
Attempted solution:
Let S = {x in [a,b] | x = a or f is bounded on [a,x]}
Thus, by definition, S is a subinterval of [a,b].
Because of this fact, S is bounded.
Because S is bounded, S has a least upper bound, call it p.
It follows that p > a must be true.
Because b is an upper bound of S, p <= b.
Now, we employ an indirect argument.
Thus, assume p < b.
By definition, b is the LUB of set [a,b].
Other questions, and relevant background:
From here on out, I'm confused about where to go and what to do. Does anyone have any pointers or suggestions? What approach do I need to take to complete this proof? The only thing I can think of is that it might have to do with f being continuous on an interval implying that f is bounded on that interval. However, I'm not sure how to prove this implication either.
Thank you in advance for your help.
It seems like you need to show there's an element of the set other than a. I mean, it's pretty obvious, but it's kind of needed, I think.
Of course, I would personally just say that a continuous function maps compact sets to compact sets, then apply Heine-Borel. But that's a copout.
Hmmm...true, but remember. Ultimately, I'm trying to show that S is [a,b]. The continuous function bit is a part of the problem I think, though it might not be.
Well, if it's discontinuous it could be that it's not bounded on any such interval [a,x] (take f(x) = a for x = a and f(x) = 1/(x - a), for x > a.
It seems to me you can do this much more efficiently if you merely use the fact that f is continuous on [a,b]. I know you ask this later in your OP, but you haven't clearly used it anywhere in your outline. Remember that f continuous on [a,b] means f achieves a max/min on [a,b].
Yeah, it seems like you're going to have to use some form of the compact sets being mapped to compact sets thing. If you want to show there's an x =/= a in the set, I think you're going to have to invoke the intermediate value theorem, which is a result of continuous functions taking on a maximum and minimum value on a closed interval, which is proved with the stated theorem and Heine-Borel.
  • · Replies 20 ·
  • · Replies 43 ·
