Electric Field due to Two Point Charges
The problem involves calculating the electric field at the origin due to two point charges located on the x-axis. The first charge is positive, while the second charge is initially positive but later considered negative. Participants are tasked with finding the electric field components at the origin and considering the effects of charge polarity.
  • The original poster attempts to calculate the electric field using the formula for electric field strength and considers the contributions from both charges. Some participants question the direction of the electric field and how it relates to the forces on a positive test charge.
Participants are actively discussing the direction of the electric field and the forces exerted by the charges on a test charge. There is an exploration of the implications of charge polarity on the net electric field at the origin. Some guidance is offered regarding drawing force diagrams to visualize the problem.
There is a mention of a potential misunderstanding regarding the placement of the second charge, which initially leads to confusion in the calculations. The discussion also notes that the thread may have been posted in the incorrect section of the forum.
cse63146
Two point charges are placed on the x axis. The first charge, q1= 8 nC, is placed a distance 16m from the origin along the positive x axis; the second charge, q2= 6 nC , is placed a distance 9m from the origin along the negative x axis.
Find the electric field at the origin, point O.
Give the x and y components of the electric field as an ordered pair. Express your answer in Newtons per coulomb to three significant figures. Keep in mind that an x component that points to the right is positive and a y component that points upward is positive.
Now, assume that charge q2 is negative; q2 = -6 nC. What is the net electric field at the origin, point O?
E = [tex]\frac{kQ}{r^2}[/tex]
I start by "placing" a test charge at the origin.
Here's what I think I should do:
E = [tex]\frac{kQ_1}{r^2}[/tex] + [tex]\frac{kQ_2}{r^2}[/tex]
E_1 = [tex]\frac{(9x10^9)(8x10^-9)}{16^2}[/tex] = 0.261 N/C
E_2 = [tex]\frac{(9x10^9)(6x10^-9)}{9^2}[/tex] = 0.667 N/C
E = E_1 + E_2 = 0.261 + 0.667 = 0.928 N/C
Am I right?
The direction of the E-field is taken to be the direction of the force it would exert on a positive test charge so when you draw a diagram with a positive test charge how would the forces from the q1 and q2 be acting on it? In the same direction or opposite?
Since all of the charges are positive, they would repel, and thus create a force pushing it to the left.
Still not sure (electircity isn't my strong point)
q1 is to the right of the test charge (placed at the origin) and q2 is to the left of it.. draw a force diagram to see
ohhhh... I thought the second charge was also placed on the positive x-axis
so would it be 0.667 - 0.261 since the force is pushing the test charge to the left?
and I just noticed that I posted it in the wrong section. Would someone be able to move it to intro physics?
