Thread Closed
12 balls
Share Thread Thread Tools
Jan26-08, 02:12 AM   #1
12 balls
You have 12 balls, and a weighing machine with no standard weighs. One of those 12 balls is either lighter or heavier than the others. Spot the ball in 3 chances with the weighing machine.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jan26-08, 11:32 PM   #2
hint:
2x6, 2x3, 2x1+1
or 2x4+4, 2x2, 2x1
Jan27-08, 04:57 AM   #3
Sorry, I forgot to mention that you must also be able to say whether the ball is heavy or light.
Jan27-08, 07:18 AM   #4
12 balls
This "puzzle" has been posted a zillion times here...
Jan27-08, 08:29 AM   #6
Recognitions:
Gold Membership Gold Member
Maybe not a zillion times, but more than 5 times.
Jan28-08, 09:55 PM   #7
Quote by Xalos View Post
You have 12 balls
I've had that dream before. Kind of a nightmare, actually. It was impossible to walk or sit down.
Oh! Okay.
6 vs. 5 + 1 lighter. Get the lighter set.
3 vs 2 + 1 lighter. Get the lighter set.
Weigh any 2 of them. If they are equal, the 3rd one is lighter.
Jan28-08, 10:06 PM   #8
Quote by Poop-Loops View Post
Thank you. I actually have spittle on my screen.
Jan29-08, 06:32 AM   #9
It is not ok: the defective ball could be in the heavier set .
Jan29-08, 11:04 AM   #10
Oh craps. I didn't notice that it could be lighter or heavier.
Jan29-08, 12:27 PM   #11
The puzzle is new to me, so here's my answer:
Weigh 4 against 4.
If they even out, select three and weigh against 3 from the remainder. If they cancel out still, and since there's 1 ball left, one more weighing will give away the answer. If not, then the foreign ball is within those 3 balls selected from the remainder. At this step, it should be clear whether the foreign ball is lighter or heavier than the others. Now say the said balls are A B C, and other random balls now known to be normal are X X X. Weigh A X against B X. If they even out, then obviously it's C, if not, then either A or B.
Now if 4 against 4 doesn't cancel out, substitute one side with the remainder. Depending on what the scale reads, determine whether the foreign ball is lighter or heavier. In any case, you'll end with a 2 against 2 weighing, which will easily give away the foreign ball by swapping two balls from each side, and substituting for 1 ball from the remainder on one side.
Jan29-08, 07:57 PM   #12
Quote by Kittel Knight View Post
I've told you a million times: don't hyperbolize!
Jan29-08, 11:08 PM   #13
Quote by Werg22 View Post
<snip>
I am pretty positive the bolded part would not work.
Jan30-08, 01:01 AM   #14
You're right, what I wrote is senseless. Impossible to determine a foreign ball out of 4 balls with only one weighing. I'll try rectifying the solution, tomorow
Jan30-08, 03:32 AM   #15
Quote by DaveC426913 View Post
You are right, Dave!
Even my mother has already told me this a billion times...
Jan31-08, 02:24 PM   #16
Ok here's the correction:
4 against 4 doesn't even out
Say we have on the heavier side A B C D and on the lighter side S T U V, and X represent a ball from the remainder. Now weigh S X X X against A T U V. If they even, out, the foreign ball is among B C D, and is heavier. If S X X X > A T U V, then the foreign ball is among T U V and is lighter. If S X X X < A T U V, weigh A against X. If A = X, then S is the foreign ball, and is lighter. If A > X, then A is the foreign ball and is heavier.
Solved
Thread Closed
Thread Tools
Similar Threads for: 12 balls
Thread Forum Replies
Weighing the balls Brain Teasers 16
I have some balls that have not been opened General Discussion 16
Billiar Balls Introductory Physics Homework 2
Red Balls, Green Balls and Expectations Set Theory, Logic, Probability, Statistics 2
2 Balls Introductory Physics Homework 5
