Double integrals and change of variables
The discussion revolves around the change of variables in double integrals, particularly focusing on the use of polar coordinates versus Cartesian coordinates. Participants explore the implications of choosing integration regions and the validity of indefinite integrals in this context.
  • One participant presents a problem with evaluating double integrals using both Cartesian and polar coordinates, noting discrepancies in results.
  • Another participant emphasizes the necessity of selecting a region for integration when transforming coordinates.
  • A question is raised about the applicability of change of variables in indefinite double integrals.
  • Some participants argue that even in indefinite integrals, a region of integration is implicitly defined.
  • There is a discussion about the correctness of integrals evaluated in Cartesian coordinates compared to those in polar coordinates.
  • One participant expresses confusion about the ability to integrate without specifying limits in polar coordinates.
  • A separate question about using double integrals to express position from acceleration is introduced, leading to a clarification about the nature of double integrals.
Participants do not reach consensus on the necessity of specifying regions for indefinite double integrals, and there are differing views on the validity of results obtained from different coordinate systems.
The discussion highlights the complexity of changing variables in double integrals and the potential misunderstandings regarding the treatment of indefinite integrals and the need for defined regions.
Students and practitioners of calculus, particularly those interested in integration techniques and the implications of coordinate transformations in multiple dimensions.
newmathman
Hi, everyone!
I have a problem in understading the change of variables in double integrals. Here is an example
[tex]\int\int x^2+y^2dx dy=\int \frac{x^3}{3}+y^2x dy=\frac{x^3y}{3}+\frac{y^3x}{3}+C_1[/tex]
but if I first do a change in poral coordinates I get
[tex]\int\int r^2 r drd\theta=\int\frac{r^4}{4}d\theta=\frac{r^4\theta}{4}=\frac{1}{4}(x^2+y^2)^2 arctan(\frac{y}{x})+C_2[/tex]
which is not the first answer. A more simple example is
[tex]\int\int dxdy=xy+C_1[/tex]
and in poral
[tex]\int\int rdrd\theta=\int\frac{r^2}{2}d\theta=\frac{r^2\theta}{2}=\frac{1}{2}(x^2+y^2) arctan(\frac{y}{x})+C_2[/tex]
Can someone explain what I do wrong?
Thanks in advance!
you have to pick a region over which to integrate and then transform that region. for example let's integrate your first integral over the quarter of the unit circle in the first quadrant in the xy plane.
[tex]\int^{1}_{0}\int^{\sqrt{1-x^2}}_{0} x^2+y^2~dydx[/tex]
in polar coordinates your integral will look like
[tex]\int^{\frac{\pi}{2}}_{0}\int^{1}_{0} r^3 dr d\theta[/tex]
Why should I choose a region? When I have to evaluate a indefinite double integral, I can't apply change of variables?
I think this is where the problem is, because you seem to think that when you evaluate an indefinite single variable integral that you aren't integrating over a "region" when in fact you are, the segment of the real line [a,x], so it is similar the in the multiple variable case that you still would need to chose an arbitrary region over which to integrate.
Ahaa! So my integrals over [tex]dx dy[/tex] are correct by the ones over [tex]dr d\theta[/tex] are not?
Actually no, since even if you're doing a double integral wrt dxdy, and not cylindrical or spherical coordinates, you'll still need to specify a region over which the integration is done.
I was referring to d_leet's post. I mean the integrals over [tex]dx dy[/tex] are correct in sense that I can evalute them and then substitude the values a<x<b, c<y<d for some region. But for integrals over [tex]dr d\theta[/tex] I can not first evalute them and then substitude the values r1<r<r2, [tex]\theta_1<\theta<\theta_2[/tex].
Does it makes any sense, or I am talking nonsenses?? :smile:
It's possible to integrate in both cylindrical and cartesian coordinates without the limits, but it's not possible to change variables without first knowing the limits. Or at least that's what I feel.
I have a general question about double integrals. Since acceleration is the second derivative of the position function, can one not use a double integral notation to express the position function as a double integral of the acceleration function, like x(t) = [tex]\int a(t) dt dt[/tex]? (I can't seem to make two integral symbols back to back, but that is supposed to be two integrals before a(t).)
1) Please don't "hijack" other people's threads for new questions.
2) A "double integral" is with respect to two different variables. When you go from acceleration to position, you are integrating, twice, with respect to time.
  • · Replies 29 ·
