Force on Magnetized Fluid: Intuitive Explanation
  • Context: Graduate
  • Thread starter Thread starter da_willem
    Fluid Force
The discussion centers on the force exerted on a magnetized fluid, specifically addressing the equations governing this phenomenon. The force on a single dipole is defined as F = ∇(m · B), while the energy of a magnetized material is represented as -μ₀ M · H. The force on a magnetized material is expressed as F = μ₀ M ∇H, highlighting the transition from using magnetic field B to magnetic field H. This shift is attributed to the principle that a magnetized material cannot exert a force on itself, necessitating the use of the external magnetic field H in calculations.
  • Understanding of magnetic dipoles and dipole moments
  • Familiarity with the concepts of magnetic fields B and H
  • Knowledge of magnetization and its role in magnetic materials
  • Basic principles of ferrohydrodynamics
  • Research the derivation of the force equations in magnetized fluids
  • Study the role of external magnetic fields in magnetization
  • Explore the principles of ferrohydrodynamics as outlined in Rosensweig's work
  • Learn about the implications of using H versus B in magnetic force calculations
Physicists, engineers, and researchers interested in magnetized fluids, ferrohydrodynamics, and the underlying principles of magnetic forces in materials.
da_willem
The force on a single dipole (dipole moment m) can be obtained by taking the gradient of its energy, i.e.
[tex]\vec{F} = \nabla (\vec{m} \cdot \vec{B})[/tex]
One also often encounters for the energy of a magnetized material
[tex]-\mu_0 \vec{M}\cdot \vec{H}[/tex]
And often the force on a material with magnetization M is written
[tex]\vec{F}=\mu_0 M \nabla H[/tex]
why the replacement of B with H? Does it have something to do with the fact that part of B is producedby the magnetization (B=mu_0(H+M)) and the material can't exert a force on itself?? Or does one necessarily have to dive into the derivations to get an idea why?
Any intuitive thoughts?
Do you have a source for your equations with H?
Probably the muzero H just stands for B outside the magnet.
The force equation with H (M gradH) (Kelvin force) is the standard expression used in ferrohydrodynamics (see e.g. Rosensweig) when dealing with dilute colloids for example.
I'm wondering if the use of H instead of B results from the fact that only the external applied magnetic field should be used in evalueating the force because the magnetized material cannot exert a force on itself. Any familiarity with these expressions?
  • · Replies 23 ·
  • · Replies 0 ·
