Simple Integration using U Substitution
The discussion revolves around finding the indefinite integral of the expression (x^2-1)/(sqrt(2x-1))dx, with participants exploring substitution methods for integration.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss using u-substitution, with one suggesting the substitution 2x-1=u^2 and differentiating to find dx. Others consider breaking up the integral into simpler parts.
The conversation includes various attempts at substitution and integration techniques, with some participants offering guidance on how to proceed. There is no explicit consensus, but several productive suggestions have been made.
One participant mentions a typographical error in the original problem statement, which may affect the interpretation of the integral. Additionally, there are references to the complexity of using LaTeX for mathematical expressions.
anon413
Find the indefinite integral.
The antiderivative or the integral of (x^2-1)/(x^2-1)^(1/2)dx
Tried using (x^2-1)^(1/2) as u and udu for dx and I solved for x but I am still left with a 1 on top not sure how to deal with it.
[tex]\int\frac{x^2-1}{\sqrt{2x-1}}dx[/tex]
Yes?
Sorry made a mistake in typing the denominator (2x-1)^(1/2) I am slightly displexic
How did you type that exactly.
Yes thank you, that command latex is complicated I'll try to learn it.
well try to use this substitution:
2x-1=u^2, try to defferentiate and substitute back what u get for dx,
you also get for x=(u^2 + 1)/2, from 2x-1=u^2
the rest is pretty simple after u substitute!
Can you go from here?
Gets easier as you use it on a daily basis.
First, I would break up the numerator.
[tex]\int\frac{x^2}{\sqrt{2x-1}}dx-\int\frac{dx}{\sqrt{2x-1}}[/tex]
It might work this way also, but by immediately taking the substitution that i suggested he will get to the result pretty fast.
Ok ill try stupid maths method I would get the integral of (((u^2+1)/2)^2-1)/(u) what would my du be
I guess I will attempt this on my own that's for the help.
You do not need to know what the du will be, you need just to plug in the value of the dx that you get after differentiating 2x-1=u^2, so it obviously will be dx=udu, and when you plug this in the u here and that one that you will get on the denominator will cancel out so you are left with somehting like this:
[tex]\int\frac{((\frac{u^{2}+1}{2})^{2}-1)udu}{u}[/tex], now you can go from here right?
By the way it is not stupid math, but instead sutupidmath! NOt that i mind it, but it feels good to be correct! NO hard feelings, ok?
thx stupidmath. I knew I got the right udu for dx.
  • · Replies 105 ·
13K
  • · Replies 22 ·
  • · Replies 44 ·
