How do you read this analog voltmeter?
  • Thread starter Thread starter FocusedWolf
    Analog Voltmeter
The discussion centers on interpreting readings from an analog voltmeter, specifically the model referenced at http://www.elexp.com/tst_7050.htm. Users are confused about which set of numbers to use for DC voltage measurements, particularly when the dial is set to different ranges. The key takeaway is that the small numbers correspond to lower voltage ranges, while the larger numbers indicate higher ranges, requiring users to understand the scale to avoid misreading values. Additional resources were shared, including links to similar meters and general documentation for analog multimeters.
  • Understanding of DC voltage measurement
  • Familiarity with analog voltmeter operation
  • Basic knowledge of electrical units (volts)
  • Ability to interpret scale markings on measuring instruments
  • Research how to read analog voltmeters effectively
  • Learn about the differences between analog and digital multimeters
  • Explore the significance of range settings in voltage measurement
  • Study the documentation for various analog voltmeter models
Electronics students, hobbyists, and technicians who need to measure DC voltage accurately using analog voltmeters will benefit from this discussion.
FocusedWolf
Hi, my lab is using these: http://www.elexp.com/tst_7050.htm
we weren't given any intro on interpreting the results.
we're measuring dc volts... its the black numbers below the shiny metal in the picture.
anyway, theirs two sets of numbers for dc volts, so we don't know which to use when... my guess is if you rotate the dial to the small range of like 2.8 volts that you use the small numbers? no idea
also, when measuring 14.0 volts, with the range set to 25, the needle rests on approzimately 140... but with a digitial volt meter we we're getting 14.23v (with its range set on 20).
My question is, depending on the range setting... how do you know if your getting 14 volts or 140 volts or 1.40 volts with this thing... basically how do you read this thing :P
man i wish their was a manual to this thing posted on the internet... can't even find a manufacturers site lol
Without being able to see the meter more clearly, I don't know that I could help. There's a ton of lettering on and around the meter that probably indicates which ranges are which, but I can't read it in that photo.
- Warren
14K
  • · Replies 87 ·
11K
  • · Replies 18 ·
