Interference of Light: Calculating Intensity at Point O with Two Offset Slits
  • Thread starter Thread starter dopher
The discussion focuses on calculating the light intensity at point O when two offset slits, B and C, are open, using the principles of light interference. The light wavelength is λ = 475 nm, and the path difference between the slits is calculated to be approximately 3.142851 E-6 meters. This results in a phase difference (phi) of 41.572874 radians. The final intensity at point O, when both slits are open, is determined using the formula I = 4(I1) cos²(phi/2), confirming that the intensity remains consistent due to the equal adjustments in path length for both slits.
  • Understanding of light interference principles
  • Familiarity with phase difference calculations
  • Knowledge of intensity formulas in wave physics
  • Basic skills in trigonometric functions
  • Study the derivation of the interference formula I = 4(I1) cos²(phi/2)
  • Learn about phase difference in multiple slit interference patterns
  • Explore the impact of slit height variations on interference patterns
  • Investigate practical applications of light interference in optical devices
Students and professionals in physics, particularly those focusing on optics and wave phenomena, as well as educators teaching concepts related to light interference and intensity calculations.
dopher
I'm having trouble getting started with this problem. I know the interference formulas and how it works, but I'm having trouble determining the phase difference (if B and C were in phase i could do it easily, but they aren't, how do I find out the phase they are initially apart?)
|----------B------------|
|----------C------------|
A----------|------------O
|<---x1-->|<-----x2--->|
Consider the above setup, not drawn to scale.
Light of wavelength λ= 475 nm is shined at normal incidence to the first screen with slit A.
The second screen, x1 = 0.7 meters behind the first screen, has two slits, B and C .
The third screen is x2 = 1.5 meters behind the second screen. It has slit O, which is level with slit A. A lightmeter measures the light intensity at the slit O.
When light is sent through slit A and measured at the slit O with either slit B or slit C open one slit at a time, the intensity at the point O is the same: I0 = 0.5 W/m2. (The slit widths can always be adjusted so that this is true, but for this problem you can/should ignore the width of all slits.)
Slit B is at height y1 = 2 mm above slit A.
Slit C is at height y2 = 1 mm above slit A.
Note that the drawing is not drawn to scale.
a) What is the light intensity measured at the point O when both slits B and C are open?
For a, you have to find the path difference between ABO and ACO. This is 3.142851 E-6. Plug this into phi = 2pi (delta) / lambda. This gets you 41.572874. Now you should have everything you need to solve I = 4(I1) cos^2 (phi/2).
B should be the same, because you're increasing both ABO and ACO by the same amount, therefore not changing the path difference.
...this is not from me...
  • · Replies 17 ·
9K
10K
