How can you create a stable 5V power supply for digital logic gates?
The discussion revolves around creating a stable 5V power supply for digital logic gates, specifically addressing the viability of using batteries versus regulated power supplies. Participants explore the performance of integrated circuits (ICs) under different voltage conditions and share experiences with circuit behavior.
  • Experimental/applied
  • One participant questions whether ICs will function properly when powered by 3 or 4 1.5V batteries without a regulator, expressing uncertainty about the equivalence of battery voltage to regulated voltage.
  • Another participant notes that while ICs may operate outside specified voltage ranges, their performance may not meet datasheet specifications, particularly regarding switching speed and thermal characteristics.
  • Concerns are raised about the arithmetic involved in achieving 5V from batteries, with one participant humorously correcting another's calculation.
  • A participant shares their experience of ICs working at school but failing at home, suggesting a potential issue with the power supply.
  • Discussion includes the operational voltage range for the 74 series ICs, with a participant stating that the 7404 can operate between 2V and 6V.
  • One participant describes a specific circuit setup with an OR gate chip that did not function as expected, prompting questions about the circuit configuration and component orientation.
  • A later reply offers a simple power supply solution using a Zener diode and mentions the risks of overvoltage with certain chips, sharing a personal anecdote about a failed component due to excessive voltage.
  • Another participant suggests using an old computer power supply as a cost-effective method for obtaining a stable 5V source.
Participants express differing views on the reliability of using batteries versus regulated power supplies, and there is no consensus on the best approach to achieve a stable 5V supply. The discussion remains unresolved regarding the specific issues encountered with circuit behavior.
Participants mention various assumptions about voltage ranges and circuit configurations, but these assumptions are not fully explored or resolved within the discussion.
david90
merged with the other thread by enigma
Will ICs work if I power it with 3 or 4 1.5 volt bat connected in series? I read that you need to use a power regulator to regulate it to 5 volt but what if you don't? Will it still work?
I guess my question is, is 5 volts from just batteries the same as 5 volts from a regulator. I tried with batteries but didn't work. Just want to confirm.
Virtually all IC's (with the exception of those that use bandgap references or PLL's, etc.) will "work" when powered by the wrong supply voltage; the problem is that they won't work exactly according to the performace specifications on the manufacturer's data sheet. Since making sure a product works according to its datasheet is a huge concern for a semiconductor company, from a liability standpoint, they don't encourage users to use them at different voltages.
If you undersupply a digital part, it'll most likely not switch as fast as it says it will on the datasheet, for example. If you oversupply it, it might get a bit too warm and degrade a noise specification. In general, though, your IC will work just fine as long as your design does not depend on being right on the edge of a specification. (Good designs don't do this anyway!)
- Warren
5V is 5V is 5V. I don't know how you got 5V from "3 or 4 1.5V batteries," though, or maybe my arithmetic is slipping.
- Warren
at school, my ICs (7400,32 etc.) works fine but when I use batteries at home, it doesn't seem to follow the truth table. I thought i might be the power supply fault.
The 74 series is very linear, and should work at just about any supply voltage. According to Fairchild, the 7404 can be operated up to 7V, with 2V to 6V the recommended range.
- Warren
I think your arithmetic is slipping. 4=1.5 = 5.
Anyway, my 7400 ICs doesn't work! it is so weird. it works at school when I use the power supply from those big box.
jk about your arithmetic. but it should somewhat work with 6 volts.
Well, since you're saying it doesn't work, what exactly doesn't it do? What exactly is different about its behavior?
- Warren
I used the OR gate chip and hooked up power to pin 14 and ground to pin 7. Then I hooked led to pin 3 and make pin 1 "high" by connecting it to pin 14. Nothing light up... I'm pretty sure the led is hook up right. cathrode to pin 3 and anode to ground. Resistor is between the led and cathrode. nohting light.
Are you sure you have the led in the right direction? Maybe the led went bad. Do you have a voltmeter to check to see if there is any output on pin 3?
[edit] Why are you saying you are using an OR gate. The 7400 is a NAND gate
problem solved. I re did my circuit. THanks all.
For future reference, you could use a 1k resistor, 47uF cap, and 5V Zener to make a simple power supply with a low idle current cost. Also you could tie the Zener to a linear regulator to handle more current as well.
I've had 15V rated 555 chips literally go up in smoke when my unloaded PS (cheapie wall transformer) would go up to 17V and I hadn't bothered to wire them up with a 12V Zener. At least it was very obvious when it happened. :)
Super cheap way to get a stable 5V source with a few amps of capacity: an old computer power supply. I picked up a couple 250W on sale for $14.99 brand new just a couple weeks ago.
Cliff
  • · Replies 29 ·
  • · Replies 20 ·
