Radius of Convergence for (-1)^n(i^n)(n^2)(Z^n)/3^n in Complex Analysis
The radius of convergence for the series defined by the expression (-1)^n(i^n)(n^2)(Z^n)/3^n is determined to be 3. The analysis employs the ratio test, where the terms of the series are evaluated as |a_{n+1}/a_n|, leading to the conclusion that |Z|/3 must be less than 1 for convergence. The limit of the ratio simplifies to ((n+1)/n)^2 Z/3, which approaches 1 as n approaches infinity. Thus, the series converges when |Z| < 3.
  • Understanding of complex numbers and their properties, specifically the modulus of complex numbers.
  • Familiarity with series convergence tests, particularly the ratio test.
  • Knowledge of limits and their application in evaluating series.
  • Basic understanding of sequences and summation indices.
  • Study the application of the ratio test in greater depth, focusing on its limitations and scenarios of use.
  • Explore the root test for series convergence and its relationship to the ratio test.
  • Investigate the properties of complex series and their convergence criteria.
  • Learn about the implications of the radius of convergence in complex analysis and its applications in function theory.
Students and professionals in mathematics, particularly those studying complex analysis, as well as educators teaching series convergence and complex number theory.
Mattofix
Find the radius of convergence of
i have got to lZl i (n+1)^2/3n^2
but am unsure how to complete it...
For the sum to converge, the norm of the terms must go to zero.
So, what is:
[tex]\lim_{n \rightarrow \infty} \left | n^2 \left(\frac{-iZ}{3}\right)^n\right|[/tex]
How and why did you "get" that? At first I thought you were using the "root test" but that won't work with the n2.
(Am I correct that "n" is the index of summation and "i" is the complex base? If so |i|= |-1|= 1)
I would be inclined to use the "ratio test": a sequence [itex]\sum a_n[/itex] converges if the ratio [itex]|a_{n+1}/a_n|[/itex] converges to a number less than 1. Here, [itex]|a_{n+1}|= (n+1)^2 Z^{n+1}/3^{n+1}[/itex] so the ratio becomes [itex]((n+1)/n)^2 Z/3[/itex]. Since (n+1)/n goes to 1, so does ((n+1)/n)^2 and we have |Z|/3< 1. The radius of convergence is 3.
