A Conducting Shell around a Conducting Rod
The discussion focuses on the electric field and surface charge densities associated with an infinitely long conducting cylindrical rod and its surrounding conducting shell. The rod has a linear charge density of "lambda," while the shell has a linear charge density of "-2 lambda." The radial electric field E(r) between the rod and shell is derived using Gauss's law, resulting in E(r) = (lambda / (2 * pi * epsilon * r)). The surface charge densities on the inner and outer surfaces of the shell are calculated as "fi - inner" = -lambda / (2 * pi * r1) and "fi - outer" = -lambda / (2 * pi * r2), respectively. The electric field outside the shell is zero due to the symmetry of the charge distribution.
  • Understanding of Gauss's Law in electrostatics
  • Familiarity with cylindrical coordinates and symmetry in electric fields
  • Knowledge of surface charge density calculations
  • Concept of permittivity of free space (epsilon)
  • Study the application of Gauss's Law to various charge distributions
  • Learn about electric field calculations in cylindrical geometries
  • Explore the concept of surface charge density in electrostatics
  • Investigate the implications of permittivity of free space in electric field equations
Students studying electromagnetism, physics educators, and anyone interested in understanding electric fields around charged conductors.
electricman
An infinitely long conducting cylindrical rod with a positive charge "lambda" per unit length is surrounded by a conducting cylindrical shell (which is also infinitely long) with a charge per unit length of "-2 lambda" and radius r1.
a) What is E(r) , the radial component of the electric field between the rod and cylindrical shell as a function of the distance r from the axis of the cylindrical rod?
Express your answer in terms of "lambda", r, and "epsilon" , the permittivity of free space.
b) What is "fi - inner" , the surface charge density (charge per unit area) on the inner surface of the conducting shell?
c) What is "fi - outer" , the surface charge density on the outside of the conducting shell? (Recall from the problem statement that the conducting shell has a total charge per unit length given by "-2 lambda" .)
d) What is the radial component of the electric field, E(r), outside the shell?
I have no idea how to solve this
Anyone that knows?
http://www.physics.wisc.edu/undergrads/courses/spring08/202/hw2sols.pdf
