| New Reply |
Solid sphere inside a hollow sphere. |
Share Thread | Thread Tools |
| Feb4-08, 09:53 AM | #1 |
Question Details:
The figure shows a solid metal sphere at the center of a hollow metal sphere. 1- What is the total charge on the exterior of the inner sphere? 2- What is the total charge on the inside surface of the hollow sphere? 3- What is the total charge on the exterior surface of the hollow sphere? These problems seem easy, but I just can't figure them out. No similar examples are found in my book. Any help is much appreciated! This is what I've done: Create an imaginary Gaussian sphere of radius 8cm so that it passes through the point where E is 15000N/C. The flux should equal to (-15000)(4pi0.08^2) = q/(8.85x10^-12) the answer i get is wrong!! |
| Feb4-08, 12:56 PM | #3 |
If this is a web-based problem, you may have used the incorrect significant figures. Since the radius is only 1 significant figure of accuracy, your answer should be only 1 sig. fig. when typed in. Give that a try So... -1x10^-8C I think is what you get.
Steve |
| Feb25-08, 02:31 PM | #4 |
Maybe you DEVIDED instead of MULTIPLYING.. make sure to multiply the FLUX on the left side of the equation X Epsilon constant...
| Mar18-09, 04:23 PM | #5 |
I have the exact same problem and I am having trouble with parts b and c. Wouldn't the inside surface of the hollow sphere just be the same charge as the solid inner sphere but positive?
Thanks, KEØM |
| Mar18-09, 08:26 PM | #7 |
Thank you for your reply. For part c, I can't say now that the charge on the outer surface of the hollow sphere is exactly negative of the charge on the inside surface of the hollow sphere can I? I think I have to use Gauss's Law and choose my gaussian surface to be a sphere with a radius 17cm long measured from the center of the solid inner sphere. Would this be right?
Thanks in advance, KEØM |
| Mar19-09, 04:58 AM | #8 |
Mentor
| Mar19-09, 10:16 AM | #9 |
Thanks again for all your help Doc Al.
KEØM |
| Apr24-09, 04:01 PM | #10 |
Question, I am doing the same problem, but i do not understand why a (-) sign is put for part A) but not B) & C).
| Apr24-09, 05:16 PM | #11 |
Mentor
| Apr29-10, 04:15 PM | #12 |
Hey I'm just wondering where did you get this quesion from because this was on my midterm and if theres a database of these questions I'd like to study from them
| May3-10, 10:48 AM | #13 |
Although I am not the original poster, I got mine from the textbook "Physics for Scientists and Engineers" by Randall D. Knight.
Sorry if that is not much help. |
| Oct23-11, 10:53 AM | #14 |
Why the inside surface of the hollow sphere has the same charge as the solid inner sphere but positive?
| New Reply |
| Thread Tools | |
Similar Threads for: Solid sphere inside a hollow sphere.
| Hollow sphere or sphere with beams | General Engineering | 2 | ||
| Potential Inside a Hollow Conduction Sphere... | Advanced Physics Homework | 2 | ||
| Force on a charge inside a hollow charged sphere | Advanced Physics Homework | 13 | ||
| Gravity inside a solid sphere. | Introductory Physics Homework | 12 | ||
| Potential inside a hollow sphere | Advanced Physics Homework | 11 | ||
