Water and Ice heat transfer equilibrium
The discussion focuses on the heat transfer equilibrium between 120 g of ice at 0°C and 210 g of water at 25°C in a glass. The key equations involved are Q=mL for latent heat and the conservation of energy principle, represented as delta Q1 + delta Q2 + delta Q3 = 0. The problem-solving approach involves determining whether the heat from the water is sufficient to melt all the ice and calculating the resulting equilibrium temperature based on the heat exchange. Two scenarios are outlined: one where not all ice melts and another where it does, leading to a straightforward heat exchange calculation.
  • Understanding of latent heat of fusion
  • Familiarity with heat transfer equations, specifically Q=mL
  • Knowledge of conservation of energy principles in thermodynamics
  • Basic algebra for solving equations with multiple variables
  • Calculate the latent heat of fusion for ice
  • Learn about heat transfer calculations in phase changes
  • Study the principles of thermal equilibrium in closed systems
  • Explore specific heat capacity and its role in temperature changes
Students studying thermodynamics, physics educators, and anyone interested in understanding heat transfer processes in phase changes.
merbear
A 300 cm3 glass is filled with 120 g of ice at 0°C and 210 g of water at 25°C.
(a) Characterize the content of the glass after equilibrium has been reached. Neglect heat transfer to and from the environment.
Find:
mass of water?
mass of ice?
equilibrium temperature?
Q=mL
delta q= 0 (for the system)
I don't know how to solve for the latent heat of fusion, so I tried to set up a series of equations from which I would be able to substitute to solve for the unknowns. I ended up with too many variables and not able to isolate them to solve for values. Since the latent heat of fusion is the heat flow necessary to bring about a phase change, I assumed that Q=mL would be a necessary equation, but I can't figure out how to implement the equation to get values. Any help on starting this problem would be appreciated!
Thank-you!
First find out whether there is enough heat in the water to melt all of the ice.
Heat reqd to melt ice = m1*L. Heat given up by water to come down to 0 C = m2*c*(25 -0).
Case 1.
If the whole ice cannot melt, find how much would melt. The resulting temp is obvious.
Case 2.
If the whole ice does melt, then the water from the ice is at 0 C will heat up to temp t, say. Then it becomes a straight forward heat exchange problem.
  • · Replies 17 ·
