Calculating Earth's Total Electric Current from Cosmic Ray Protons
  • Thread starter Thread starter Saladsamurai
    Protons Ray
The problem involves calculating the electric current intercepted by Earth's surface due to cosmic ray protons, given a specific rate of protons per second. The context is rooted in physics, particularly in understanding electric current and charge flow.
  • Participants discuss the need to convert the rate of protons per second into a corresponding charge per second to determine the current. Questions arise regarding the charge of a proton and how to relate the given rate to the total charge intercepted.
There is an ongoing exploration of the relationship between the number of protons and their charge. Some participants have provided definitions and clarifications about current, while others express confusion about the conversion process. Multiple interpretations of the problem are being considered.
Participants note the absence of a time interval in the problem statement, which adds to the confusion. There is also a recognition that not all participants may be familiar with the charge of a proton, which could impact their understanding of the problem.
Saladsamurai
[SOLVED] Cosmic Ray Protons
Earth's atmosphere is constantly being bombarded with cosmic ray protons that originate somewhere in space. If the protons all pass through the atmosphere, each square meter of Earth's surface would intercept protons at at the average rate of 1500 protons per second. What would be the electric current intercepted by the total surface area of the entire planet?
Surface Area of sphere=4*pi*r^2
Okay, I don't even understand what this question is asking.
It wants to know the total # of protons the surface will intercept. I get that. But then it gives a rate protons per second, but does not give a tine interval.
I am lost on this one :/
All you need is the rate at which charge is intercepted, which is given. (What's the definition of current?)
From how I am understanding it. Current is defined as flow of charge (charge/time). So if they are asking for current it would be on a per unit time basis. I think the main part of the problem is how to convert protons/sec into charge/sec.
Why would that be a problem? Does mankind not know the charge of a proton yet?
All I can find for a definition of current is [itex]i=\frac{dq}{dt}[/itex] where i is in ampheres and dq is in Coulomb's. . . hmmm. So I would need to convert [itex]1500*4\pi R_{earth}^2[/itex] into Coulombs?
uhh mankind does, but maybe some students don't (as witnessed by this thread)?
You're on the right track. [itex]1500*4\pi R_{earth}^2[/itex] gives you protons per second. What's the charge of a proton? The current would be in Coulombs/second or Amps.
Doc Al said:
You're on the right track. The current would be in Coulombs/second or Amps. What's the charge of a proton?
Isn't it just 1e? I don't follow. . . or are you going to follow that question with "now how many e are in one Coulomb" . . . cause if you are, I would have to say 6.25(10^18) and then I would have to do a simple chain conversion and get the right answer!
Thanks,
Casey
Now someone please help me with my trig before I burn down this town! J/K, but seriously please someone check out my finding the angle thread.
I would have said: What's the proton charge in Coulombs? e = 1.60217646 × 10-19 C. (But same difference.)
Point taken (somewhat) :smile:. I am sure that the student knew the charge of a proton. The problem lied in correlating the number/sec and the corresponding charge/sec.
As Doc mentioned, you're on the right track.
If N particles/sec, each of charge e+, pass some point, the current I = Ne.
Yeah. I did too many extracurricular activities in my late-teens/ early twenties. . . I cannot afford to memorize all these conversions, so I just memorize one and derive the others from it!:smile:
