Airflow for Garage Woodworking Shop: Does Box Size Matter?
  • Thread starter Thread starter Bob3141592
    Airflow
The discussion revolves around the design of a dust collection system for a garage woodworking shop, specifically focusing on the impact of the manifold box size on airflow performance. Participants explore theoretical and practical aspects of airflow dynamics, dust separation, and system efficiency.
  • Experimental/applied
  • One participant describes their setup involving an 8" square by 5' box manifold with various hose sizes and questions whether the dimensions affect airflow at the tool.
  • Another participant asserts that the manifold dimensions should not impact performance as long as it is larger than the combined hose sizes, but acknowledges that slower airflow can aid in dust separation.
  • A third participant provides a resource link for further information on dust collection basics, suggesting that it may clarify the topic.
  • The original poster expresses concern about airflow losses and emphasizes the importance of getting the design right the first time, given their specific dust collector model and setup.
Participants exhibit differing views on the significance of the manifold box size, with some arguing it does not matter while others suggest it could influence performance due to airflow dynamics. The discussion remains unresolved regarding the optimal design considerations.
Participants have not fully explored the assumptions regarding airflow dynamics and dust separation efficiency, nor have they resolved the implications of different manifold sizes on overall system performance.
Bob3141592
I'm setting up a dust collection system for my garage woodworking shop. My plan is to build a manifold for various tools to feed into, with a single 4" exhaust port connected to the dust collector. This manifold is an 8" square by 5' box, with 4", 2 1/2" and 1 1/2" hoses going into it. All unused hoses will be blocked off by blast gates on the manifold. My question is: Do the dimensions of this box make much difference to the airflow at the tool? I know the airflow inside the larger volume box will slow, so that's why I'm putting the exhaust at the bottom. I think the air speed should pick up again in the narrower hose to the tool, but I'm not sure. I could make the box cross section only 5" square if I had to, but 8 is more convenient. Do you think it matters to performance?
By definition, the dimensions of the manifold make no difference in the performance (the point is that it has to be a fair bit larger than the sum of the sizes of the hoses going into it). However, as the airflow is slower inside the box, it will work as a dust separator - the dust will collect at the bottom of the box.
One other issue - if you consider how much airflow there is to get a vacuum cleaner working, you're talking about needing a pretty big fan.
Better than i can describe, here is a good site that should tell you all you need to know.
Check out dust collection basics.
http://billpentz.com/woodworking/cyclone/Index.cfm
Thanks, Russ. I suspected as much, but wanted to be sure before investing the materials and effort. The dust collector is a 1 HP Delta model with a lower bag for chips and shavings and an upper bag for finer particles. It's good for one tool at a time, which is why I'm trying to minimize airflow losses to leaks and friction. The hoses and manifold will be well grounded inside and out. It's not something I want to build twice, so I appreciate your help in getting it right the first time.
  • · Replies 42 ·
  • · Replies 21 ·
  • · Replies 48 ·
23K
