Thread Closed
[SOLVED] Ideal gases
Share Thread Thread Tools
Feb5-08, 09:49 AM   #1
an air bubble of volume 20cm^3 is at the bottom of a lake 40m deep where the temp is
4C, the bubble rises to the surface which is at temp 20C, take the temp of the buble to match that of the surrounding water, just as the bubble reaches the surface, what is it's volume?
2. Relevant equations
pV=nRT
p(f)V(f)/p(i)V(i)=nRT(f)/nRT(i)
final pressure= 1.01*10^5Pa
V(i)=20x10^-6m^3
T(i)=277K
T(f)=293K
3. The attempt at a solution
would need to determine the pressure on the bubble at the bottom of the lake, which I can't remember how to determine
p=hp(density)g?
p=40m(1000kg/m^3)9.8m/s^2
p=39.2x10^4
Vf=(T(f)*(p(i)V(i))/(T(i)p(f))
Vf=(293 * 39.2x10^4 * .00002)/(277*101000)
Vf=2297.12/2.7977x10^7=8.2x10^-5m^3
This shows the volume decreased, wouldn't the volume increase?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Feb5-08, 10:29 AM   #2
Recognitions:
Homework Helper Homework Help
You don't actaully need the value of nR, just set PV/T equal for the top and bottom.
The extra pressure of the water is just the depth * density * g, so for fresh water each 9.8m is 1 extra atmosphere, remember to add on the atmospheric pressure.
As you said the bubble should expand - It's always worth thinking about the answer before you start punching numbers.
The pressure goes down by a factor of around 5 and the absolute temperate goes up by less than 10% so you are looking for an expansion of around 5.
Feb5-08, 10:42 AM   #3
ok
so p=1.01 x 10^5Pa + 39.2x10^4
p=4.93 x 10^6
(293*4.93x10^6*.00002)/(277*101000)
V(f)=28889.8/27977000
V(f)=103cm^3
I think that is the correct answer-Thanks
Thread Closed
Thread Tools
Similar Threads for: [SOLVED] Ideal gases
Thread Forum Replies
[SOLVED] Ideal Gases Introductory Physics Homework 2
Ideal Gases Introductory Physics Homework 1
ideal gases. what fun. please help!! Introductory Physics Homework 3
Ideal Gases Introductory Physics Homework 8
ke of ideal gases General Physics 7
