| Thread Closed |
Wave on a string problem |
Share Thread |
| Feb5-08, 10:17 AM | #1 |
If y(x,t)=(6.0mm)sin(kx+(600rad/s)t+[tex]\Phi[/tex]) describes a wave travelling along a string, how much time does any given point on the string take to move between displacements y= +2.0mm and y= -2.0mm? 2. Relevant equations I think y(t)=ym sin([tex]\omega[/tex]t) ? 3. The attempt at a solution well if I plug in 2.0mm for y, 6.00mm for ym and 600rad/s for [tex]\omega[/tex] I come up with the equation 2.0mm=6.00mm sin (600rad/s * t). Where do I go from here? are my assumptions correct so far? Other things as I am thinking- 600rad/s is about 95.5Hz so each complete cycle from +6mm to -6mm should take .01s or so, so my answer should be less then that. Thanks for your help |
| Feb5-08, 11:21 AM | #2 |
anyone?
| Feb5-08, 02:32 PM | #3 |
I think I have it- if I then take
sin[tex]^{}-1[/tex](2/6)=600*T1? sin[tex]^{}-1[/tex](-2/6)=600*T2? then [tex]\Delta[/tex]T is T1-T2? does anyone have any input here? |
| Feb5-08, 08:12 PM | #4 |
pretty sure I've got it-
y1(x,t)=ym*sin(kx+600t1+[tex]\Phi[/tex]) 2.00mm=6.00mm*sin(kx+600t1+[tex]\Phi[/tex]) sin[tex]^{}-1[/tex](1/3)=kx+600t1+[tex]\Phi[/tex] y2(x,t)=ym*sin(kx+600t2+[tex]\Phi[/tex]) -2.00mm=6.00mm*sin(kx+600t2+[tex]\Phi[/tex]) sin[tex]^{}-1[/tex](-1/3)=kx+600t2+[tex]\Phi[/tex] so... [sin[tex]^{}-1[/tex](1/3)]-[sin[tex]^{}-1[/tex](-1/3)]=(kx+600t1+[tex]\Phi[/tex])-(kx+600t2+[tex]\Phi[/tex]) and... [sin[tex]^{}-1[/tex](1/3)]-[sin[tex]^{}-1[/tex](-1/3)]=600t1-600t2 finally, ([sin[tex]^{}-1[/tex](1/3)]-[sin[tex]^{}-1[/tex](-1/3)])/600=t1-t2 do the math and [tex]\Delta[/tex]t is .00113s I think this is solved |
| Jul27-09, 08:43 PM | #5 |
no one ever responded to this guys problem, and now i'm actually trying to solve this as well and i tried doing the method he ended up using but i am not getting a correct answer. Although his method for the most part looks right and makes sense to me, the only thing I figure would be the problem is that x isn't a constant so they should cancel i don't think....but i'm not sure what else to do with so many unknown variables...any help???
| Jul27-09, 08:49 PM | #6 |
oops nevermind...my calculator was in degree mode instead of radian mode
| Thread Closed |
Similar discussions for: Wave on a string problem
| Speed of a wave on a string | Introductory Physics Homework | 2 | ||
| Wave along the string | Introductory Physics Homework | 2 | ||
| Frequency of wave on a string | Introductory Physics Homework | 11 | ||
| wave on string. | Classical Physics | 17 | ||
| wave on a string | Introductory Physics Homework | 5 | ||
