How Far Can a Brass Block Be Placed on a Rotating Turntable Before Sliding Off?
The discussion focuses on determining the maximum distance a brass block can be placed from the axis of a rotating turntable before sliding off, given a coefficient of friction (µ) of 0.21 and a rotation speed of 33 1/3 revolutions per minute (T = 3.49 rad/s). The key equations involve the balance of forces, specifically µsN = m(v^2/r) and the relationship between linear velocity and angular velocity. The user struggles with manipulating these equations to find the correct distance.
  • Understanding of circular motion dynamics
  • Familiarity with friction coefficients and their applications
  • Ability to manipulate equations involving angular velocity and linear velocity
  • Knowledge of free body diagrams for analyzing forces
  • Study the derivation of the centripetal force equation in circular motion
  • Learn how to calculate angular velocity from revolutions per minute
  • Explore the relationship between frictional force and normal force in detail
  • Practice solving problems involving forces on rotating objects
Students in physics or engineering courses, particularly those studying mechanics, as well as educators looking for examples of circular motion and friction applications.
emma_elizabet
Circular Motion and Friction (PLEASE HELP!)
The coefficient of friction between a certain brass block and a large revolving turntable is µ = 0.21. How far from the axis of rotation can the block be placed before it slides off the turntable if the turntable rotates at a constant rate of 33 1/3 rev/min (so that it requires time T = 60/33.33 seconds to complete one revolution) ?
I think that µsN=4(pi^2)(mrf^2) should work, except I don't understand how to solve this sans any mass or other information.
All I can get is that T=3.49 rad/s. I just don't understand how to do this problem!
Since you are dealing with forces here, the first thing you want to do is draw a freebody diagram to account for all of the forces acting on the ring.
Then decide what theory you wish to apply to solving the prolem. Do you have this done? As it will be easier for us to guide you if you do.
So I got F=mews=mg. F also =m(v^2/r). Insert equation for v=(2pir)/t into quation for F, and then set the two F equations to be equal to each other, ultimately resulting in mewsg=((2pir)^2/T)/r. I simply cannot get the numbers to manipulate correctly and I keep getting wrong answers.
  • · Replies 20 ·
  • · Replies 16 ·
