What Is the Pressure on the Upper Wing Surface During Level Flight?
  • Thread starter Thread starter ~christina~
    Airplane Forces
The problem involves calculating the pressure on the upper wing surface of an airplane during level flight, given the mass of the airplane, the area of the wings, and the pressure on the lower wing surface. The subject area pertains to fluid dynamics and pressure differentials in aerodynamics.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the rearrangement of equations related to forces and pressures, with some questioning the dimensional consistency of the equations used. There is a focus on understanding why negative pressure values were obtained and whether there might be a typo in the provided answer.
The discussion is ongoing, with participants providing feedback on each other's calculations and interpretations. Some guidance has been offered regarding the correct formulation of equations, and there is a recognition of potential discrepancies in the provided answer. Multiple interpretations of the problem setup are being explored.
Participants are working under the constraints of homework rules, which may limit the information available for solving the problem. There is an emphasis on ensuring that all terms in the equations are dimensionally consistent.
~christina~
An airplane has a mass of 1.60x10^4 kg and each wing has an area of 40.0m^2. During level flight the pressure on the lower wing surface is 7.00x10^4 Pa. Determine the pressure on the upper wing surface.
http://img168.imageshack.us/img168/617/41426717vo3.th.jpg
[tex]\sum F= F_L -F_u - F_{mg} = 0[/tex]
My basic problem is that I keep getting a negative number for the pressure which is odd
[tex]F_u = F_{mg}- F_L[/tex]
P= F/A
[tex]P_u= Mg - P_L A[/tex]
[tex]((9.8m/s^2)*(1.60x10^4kg))-((40.0m^2)(7.00x10^4Pa))= P_u[/tex]
[tex]-2,643,200 = P_u A[/tex]
[tex]P_u= -66,080 Pa[/tex] =>
my problem is why is it negative?? is it because it's force is downward??
Plus..the answer that was given (only the answer) was 6.80x10^4 Pa so I must have done something wrong. However I ccalculated it 3 times and I still get the same answer.
Thank you very much =D
First of all, your rearranging of the equation has an error:
You start with
FL - Fu - Fmg = 0
Now add Fmg to both sides of the equation, and subtract FL from both sides:
- Fu = Fmg - FL
This is not what you arrived at. The discrepancy explains your errant minus sign
Your third equation also makes no sense. You have written:
Pu = Mg - PLA
But Pu is a pressure whereas Mg and PLA are forces. You can't equate a pressure to a force. Your equation is not dimensionally consistent. Does this help?
You start with
FL - Fu - Fmg = 0
- Fu = Fmg - FL
Hm I still get the same answer...just without the negative. 6.60x10^4Pa
Pu = Mg - PLA
I actually forgot to type that in. On paper I did add that in.
I get the same answer as you, too.
okay then, I'm suspecting it might be a typo.
I don't think you understand. This equation that you have:
Pu = Mg - PLA
is WRONG, because the thing on the left-hand side is a pressure, and the quantities on the right-hand side are forces. Therefore your equation is not dimensionally consistent: it is in error and you need to fix it.
Either have all pressures or all forces.
Pu = Mg - PLA
this is what I have:
[tex]P_u A= Mg- P_L A[/tex]
(technically now all forces)
I used this in my calculations.
Is its still wrong?
Well, it should be
[tex]-P_u A= Mg- P_L A[/tex]
because of what we talked about before with the sign error. But other than that, it looks ok.
When I plug in the numbers, I get
[tex]P_u = 6.6076 \times 10^4 \ \ \textrm{Pa}[/tex]
So if the book says 6.8*10^4, then maybe it IS a typo.
Sorry I misinterpreted what you were saying before about how you used the correct formula on paper, without the typo.
cepheid said:
Well, it should be
oh yep and I corrected that..
Okay, thanks :smile:
13K
11K
21K
