Visualizing Components of Energy Momentum Tensor
  • Context: Graduate
  • Thread starter Thread starter quantumfireball
This discussion focuses on visualizing the components of the energy momentum tensor, specifically through the lens of a second rank tensor (T_ij). The geometric interpretation involves representing the tensor as a cube, where the diagonal components correspond to pressure and the tangential components represent shear. The components T_xz and T_zx are illustrated as unit areas in the yz and xy planes, respectively, demonstrating their symmetric nature and how they deform the cube. This visualization technique, while simplistic, effectively conveys the fundamental concepts of the energy-momentum tensor.
  • Understanding of second rank tensors and their properties
  • Familiarity with the concepts of pressure and shear in physics
  • Basic knowledge of geometric interpretations in tensor analysis
  • Awareness of the symmetry in stress-energy tensors
  • Explore advanced visualizations of the energy-momentum tensor using software like MATLAB or Mathematica
  • Study the Maxwell stress tensor and its geometric interpretations
  • Investigate the implications of tensor symmetry in physical applications
  • Learn about the role of the energy-momentum tensor in general relativity
Physicists, engineers, and students studying continuum mechanics or general relativity who seek to deepen their understanding of tensor analysis and its applications in energy-momentum concepts.
quantumfireball
How to visualize thhe components of the energy tensor?
I mean to say that what it means to say that "the amount of x component of momentum flowing in the z direction per unit time"??
how can x compononent of momentum flow in some other direction
how to visulaize this geometricallty?
One way is to consider a second rank tensor (T_ij, for example) as the surface of a cube. On each face there are three orthogonal directions, one perpendicular and two tangent to the face.
The perpendicular components, taken together, are the diagnonal components of the tensor and correspond to pressure- the component acts to compress or expand the cube. The tangential components correspnd to shear- the action is to convert the cube into a rhombus.
So, T_xz could be visualized as a unit area oriented in the yz plane, and you are interested in the in-plane component pointing along the z-axis. T_zx would be a unit are lying in the xy plane, with the component of interest pointing in the x-direction. If you draw this out, you will see that those two components T_xz and T_zx act to deform the cube the same way, and indeed the stress tensor is almost always symmetric.
It's crude and doesn't translate well to other stress-energy tensors like the Maxell tensor, but it's usually good enough.
Since the energy-momentum tensor is typically symmetric, you could try to visualize it as an ellipsoid.
  • · Replies 18 ·
  • · Replies 39 ·
  • · Replies 30 ·
  • · Replies 16 ·
  • · Replies 60 ·
